Question about Mitsubishi VS-6041 60" Rear Projection Television
Can't get video inputs to change from ant a & ant b. How do i get into menu without remote
  • bigruffes Jun 03, 2010
    Inputs in front of tv. Will only change from input a&b. But tv is solid black.
  • 597 Answers
Input controls in front or side of TV
Posted on Jun 03, 2010
  • Kenneth Lee Sr. Jun 04, 2010
    Your TV is cable? It should be connected to AV 1-5.
    Make sure that your TV is connected to ANT A or B.
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
Insignia ns27rtv can not change input without remote
As there is no menu button on the front of the TV, you must have its remote control to select he inputs.
Jan 11, 2013 | Insignia Used Original NS27RTV Remote...
I changed the video input on my memorex tv and I'm not sure how to change it back without the remote
Use the menu button to get into the set's menu and try to program without a remote----failing that GOOGLE the model number to locate a new remote.
Mar 17, 2012 | Memorex Televison & Video
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
I cannot find my remote because I do not use it as I have direct tv remote. Somehow my tv got switched to ant and I need to change my video input. Can I do this on the tv without the remote
Usually you can use the front panel buttons to select "input " or video source.depending on your make/model.Reprogram your direct remote or get a universl remote.
Check link it may help:
www.remotecodelist.com/
Oct 23, 2009 | Sansui Televison & Video
Tv/video mode with no remote
you should have a menu button on the
frount of the tv press it and then select
with the (ch up) (ch dn) to highlight the
input/sorce or ant select with the enter
button then (ch up ) ( ch dn) highlight
video 1 or 2 press enter .
If this was not helpful tell me the
model # and look it up on my data base.
Rob
Sep 21, 2009 | Microsoft Xbox 360 Console
Change video input witho remote
There might be an input button or menu button on the front of the TV (or behind a door or panel) that will let you set it for video input.
May 20, 2009 | RCA E13309 13-Inch Diagonal XL-100 Color...
How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Jan 08, 2009 | RCA Scenium L50000 Television
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Televison & Video Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
