Question about Sylvania LD320SSX LCD TV
Screen times out when pc is connected hdmi--- I have a Sylvania LD320SSX Tv with a dell desktop connected through the hdmi por via dvi/hdmi adapter. the desktop has an ATI x300 pcie graphics card. The problem is if I switch input source on tv when I return to HDMI1 there is no picture. pc has all power save options disabled.
3 Suggested Answers
  • 8457 Answers
SOURCE: Blurry picture sylvania ld320ssx LCD TV when connected to ps3
Must change the Signal Tuner board.U well have good video after that.Not than 100% ur LCD Black projection Screen is dead not worth repairing.
Posted on Jan 17, 2010
JulesPCaut
  • 702 Answers
SOURCE: connect to PC via hdmi-hdmi cabel (3m)& hdmi to DVI converter
First try installing the latest ATI video driver, to make sure the HDMI output is fully supported.
Did you set your TV to select the HDMI input? nothing shows?
Posted on Dec 03, 2010
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
Tip
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
Does it have HDMI port
Look at the manual from the following link, it appears that there is no HDMI port however there is a DVI connection. A DVI to HDMI adapter can be purchased for $4 that should work.
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_inspiron_desktop/inspiron-531_owner%27s%20manual_en-us.pdf
Dec 27, 2014 | Dell (Inspiron 531) PC Desktop
Is it possible to broadcast from a Dell Dimension 5150 via dvi to HDMI Sony Bravia?
Yes it is possible if the TV has a DVI input , if it does not you need an DVI to HDMI adaptor
Jun 13, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can i connect my tv thru a dell optiplex745
Does your TV have a VGA port? If not it most likely has an HDMI port. Does your PC have an HDMI out on the video card? If not then you will need a VGA to HDMI adapter, OR a DVI-D to HDMI adapter, depending on if your GPU output is VGA or DVI-D. Then you will need an HDMI cable to go from the TV to the adapter.
Oct 17, 2013 | Dell OPTIPLEX 745 PC Desktop
How can i connect dell dimension c521 to my tv my tv has a MDMI AND A DVI put cant fine thime on my pc
You can either buy a Graphics card with HDMI/DVI on or purchase a VGA to DVI adapter from most computer retailers.
~Plug the adapter into the TV and the cable from the PC to the Adapter.
Feb 16, 2010 | Dell Dimension C521 PC Desktop
I have a dell dimension 8400. The graphics card has VGA, S-video, and DVI outputs. I want to connect my plasma tv. I purchased a DVI to HDMI adapter and connected the two with an HDMI cable, but the...
You may have left out a couple of steps.
Now, you need to configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab.
The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate.
If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
Now, again, reboot your PC to apply the changes.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Dimension 8400 PC Desktop
Jan 17, 2010 | Sylvania LD320SSX LCD TV
How do i connect my compaq pc to tv
Without the model number comptuer, I cannot verify what outputs your comptuer has. Without this, I will provide the various ways a PC can be connected to a TV.
1. Use a VGA to DVI adapter (HD-15 pin to DVI). Use either a standard VGA montor extension cable (cheaper) or a DVI extension cable (more expensive) to make the connection
2. If you computer has a DVI output, use a DVI extension cable only
3. If your computer has HDMI output - use a HDMI to DVI adapter and either a HDMI or DVI extension cable.
In all 3 cases, you will probably need to go to the comptuer's Display Properties and adjust the screen size so it looks OK on your TV (go to the Control Panel - find Display) and adjust the screen resolution to match the format of your TV.
One note - when purchasing DVI cables, understand that there are 3 types - DVI-D (digital), DVI-A (analog) and DVI-I (digital and analog) and that the pin outs are different. Be sure to check your the owners manual of your TV to find which connection it needs.
Here is a good reference for DVI types
http://www.interfacebus.com/Design_Connector_Digital_Visual_Interface_DVI_Bus.html
Dec 02, 2009 | Compaq Computers & Internet
Connect pc to tv
you can connect it to a modern flat panel via the vga port but you won't get 1080p resolution.I would suggest upgrading sound card and go for the fastest network possible for streaming wifi i'd suggest 802.11n (although 802.11b can stream with minimal network traffic).gigabit is ideal for high definition streaming.If you decide to upgrade acer makes a nice small pc the ax1200 perfect size for a nedia center though no wifi has hdmi dvd burner for less than $400 comes with 20"monitor.
Jun 26, 2009 | Computers & Internet
Sylvania LD320SSX LCD TV Logo
57 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
