Question about Sony VAIO PCG-K23 Notebook
Occasional colored vertical lines on the screen at startup
Once in a while when I start the computer, the monitor displays brightly colored vertical lines of differing widths. If I power it off and on a few times, it has eventually booted up normally. Does anyone know what the problem might be or if it is serious or not?
  • Anonymous Mar 14, 2014
    only happens occasionally, but screen gets fuzzy with vertical squiggly lines - can't see what's on the screen
  • 77 Answers
Base on our experience.... you are looking at a possible screen problem. Is it serious? yes as the screen replacement costs almost half of the total cost of the laptop.
but no harm trying this
1. remove the screws from the LCD bezel, remove the screen
2. detach the cable and reinsert them all both the inverter and the flex cable.
inverter is the circuit usually located at the bottom of the screen and the flex cable is the ribbon that runs from the laptop to the back of the lcd.
reseat them and see if your display improves
Posted on Apr 09, 2008
SOURCE:
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
Hello, I have a Dell U2711 monitor that now displays just a bright white screen. I was using the monitor, when it started getting brighter and developed a series of vertical lines in a repeating pattern...
Dell technical support number by dial Dell helpline number 1-80-243-0019 to get Dell customer support services to repair Dell Computer, Laptop, Printer.
Apr 14, 2017 | Dell U2711 27 inch LCD Monitor
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
CRT Monitor Displays only a thin bright horizontal line
Vertical IC loose connection. Best is to reflux it or resolder. It is in internal circuitry inside the monitor commonly an upside single line IC.
And its a minor repair only. But I recommend it to be serviced by a qualified technician. Inside it are plenty of nasty voltages. It might caught you.
Apr 10, 2009 | Computers & Internet
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Monitor displays only horizontal line
hey bro.
you try to re solder the vertical section and the color section.
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Sony VAIO PCG-K23 Notebook Logo
359 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
