Question about Casablanca Fan Stealth 3211T Ceiling
Cassablanca Stealth Fan rotates only in reverse direction
Hello, my Cassablanca Stealth Fan now only rotates in the reverse direction. Its peed still can be controlled by the remote, but not the direction. Is there a way to fix this problem? Thank you very much
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. What I found in the manual Is this: The direction of airflow can be changed from downward to
upward or from upward to downward.
To reverse the airflow:
1. Make sure the is on.
2. Press the button
Posted on Jun 02, 2010
  • 4 more comments
  • nikto1j Jun 02, 2010
    Hello Heath, thanks for your reply. My fan used to change directions, but now it stopped responding correctly. Once the reverse button is pushed, I can hear a click in the fan and it slows down a bit, but then picks up speed again and continues rotating in the same direction. Do you have any idea what causes this problem and if there is a way to fix it? Thanks, raisa
  • Heath Moyer Jun 02, 2010
    It may not be able to be fixed but I want you to try turn the fan off and let it stop turn the fan to on and as soon as you start it push the reverse button and see if the fan will sart the opposite way.
    I tried it a number of times. Unfortunately, this trick didn't work.
    Try spinning the fan back in the opposite direction before turning it on and hitting the reverse button.
    i did it a number of times. it really doesn't work.
    The fan is probaly shot and will need to be replaced.
Chief Leun ceiling fan 54-OR somehow changed directions. No reverse switch on fan how do I change it
Every fan has a reverse switch, it is on the barrel of the fan above the blades. small black switch, down is normal up is reverse rotation.
Jul 01, 2017 | Dryers
How do i change the direction of the rotation of the blades on a model 52-DA? I understand it's done through the remote control but I don't have the instructions for the remote.
There may be a switch on the side of the wiring housing to effect reverse rotation. If the remote does not have a fan reversal button, it can't reverse rotation.
Jul 05, 2016 | Hampton Bay Dryers
2001 mazda mpv radiator fan rotates clockwise or counterclockwise?
it should pull the air inward if its not reverse the the wires and it will reverse the direction of the fan
Jun 12, 2012 | 2001 Mazda MPV
How do you reverse the fan to move the oppisite direction for summer. Our fan is controlled by a remote.
My parents had a cassablanca fan that utilized a three button remote and if I am not mistaken to reverse the direction you held down two of the buttons at the same time for approx 3 seconds and the fan would make a different beeping sound than it does normally when changing fan speeds and bingo it changes direction. It should work, all fans work basically the same . Good Luck
Jun 27, 2010 | Hampton Bay 23509 Fulton Ceiling Fan
Can not find directions to reverse fan rotation for summer
it should be a simple slide switch on the side of the housing that moves up and down to change the direction of rotation of the fan motor and blades. look at the manual that came with the fan to make sure it has this feature but i personally have never seen a fan without one.
May 30, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Aug 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Location of reverse switch
There should be a little black switch in the center of the fan. That is to reverse rotation. Make sure the fan is off when you switch it.
Jun 25, 2009 | Hampton Bay 24002 Ceiling Fan
Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Apr 28, 2009 | Emerson CF2600PW Raphael Pewter Ceiling...
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Casablanca Fan Stealth 3211T Ceiling Logo
130 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
