SyncMaster 204B slow to light up
  • 11,361 Answers
Check leaking/bulging caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 02, 2010
When I attempt to bring it back up, or turn it on,monitor screen stays black long time, then flickers, then slowly, ever so slowly, comes into view. Works ok at that point. Happening every time now, and...
The Samsung 204B monitor have a know issue with failing power supplies that cause the exact problem you are having. At first they are a little slow to display a picture and the more you keep using it the longer it takes for the display to come on. The repair is simple if you can solder. Here is a link to a site with additional information on this repair. http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ This Samsung 204B monitor is a great unit with a simple to solve issue. No need to trash a good unit.
I hope this helps, if so please rate our solution.
BuddyMc
Jul 04, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
I am looking for the pdf file Samsung 204B fix
A full repair guide with dis-assembly and repair instructions is available at:
I hope this helps, if so please rate my solution.
BuddyMc
Aug 03, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor flickers and turns off. samsung syncmaster 204B.
this is very frecuent in all monitors or tv's lcd .... turn on 3 seconds and off the capacitors need to be replaced y sugest a technician
Sep 16, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B The blue power button is on but the screen is black. When I turn it off and back on it shows the screen for a second then goes black. Can you please help me. Thanks
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
Apr 02, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204 Samsung monitor has no power
Have you tried to plug it in else where?
If you did and still same problem then from what you said I was hopping that it wouldn't be your problem, but you will need a new monitor.
Mark
Mar 29, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung Syncmaster 204B
Try to replace C110 and C111 in the power supply circuit. These are 820uF caps and are in parallel. I had slow start and a flicker on this same monitor. Replacing the caps fixed it. Good luck, Ryan
Jul 09, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Open Questions:
Toshiba Virus Removal ' Remove Toshiba Virus - DataAlign ' Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
May 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
