Question about Lowrance X96 200khz Fishfinder
Cannot do hard or soft reset of X96. Unit worked fine for several months. It has always been attached to a Minkota trolling motor without problem. Now the depth indicator starts flashing, and freezes up, also the fish finder stops, and the unit only records water temp. Works in demo mode only. Have tried the unit without motor with no success.
3 Suggested Answers
  • 4 Answers
SOURCE: Lowrance x96 does not function after 20 feet depth
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
Posted on May 27, 2009
  • 30 Answers
SOURCE: How do you get the fish to show up on the screen
Are you looking for the little fish symbols?
Press MENU, down arrow to SONAR FEATURES and press ENT. Arrow to FISH SYMBOLS and press ENT. Press EXIT twice. Any significant return in the water will now show up as a fish symbol.
Are you looking for the fish arches?
You won't get any arches unless the boat is moving and of course there are fish passing within the transducers signal. The shallower the water, the less area you are covering and less likely to get a fish return.
There is an OK guide to understanding what you see on the sonar screen at the link below. It if pretty technical but parts of it may help you out.
http://primus.lowrance.com/support/resultDisplay.do?gotoLink=5&docType=1000&contextId=351%3A5.47%2C11918.11930%2C22.47&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FSonar&contentId=9de88fa2-0b60-4b44-a470-29ee14767b3e&responseId=135ccbe2cfd4f608%3A1fe88d%3A122773df7e0%3A7c2&groupId=4&answerGroup=1&score=981&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FSonar%2FChart+Tutorial.htm&result=0&excerpt=Chart+Tutorial+Deciphering+Sonar+Charts.&question=chart+tutorial&resultType=5000#Goto5
An X96 owners manual can be downloaded from http://www.lowrance.com/en/Downloads/Manuals/
Posted on Jul 14, 2009
Lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Why does the switch keep burning out?
call the 800 number on the motor for min kota they are great about ansering these questions. the first thought for me is that things are heating up due to too much amperage being drawn by the motor or a loose connection.you will needs to check the specs on that motor to tell and need to know what normal readings are which minkota will gladly supply you.
May 17, 2010 | Minn Kota Endura 30 Freshwater Transom...
Riptide RT65 24 volt with auto pilot goes nuts.
your magneto is shorting [ arcing on high needs, openup and replace magneto. call minkota and order a new magneto for your model, unless under warrantee.
Apr 13, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
Hard foot pedal
On the base of the foot pedal there is a tensioner for the cable. Try loosening or tightening that first. If you still have the manual from when you bought it, it is explained in deatil in there. It's a common issue - not to worry!
Jul 28, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota 54lb hooked up backwards (Pos. to Neg) wont work
Unfortunately, those units have a circut board at the power source and if there is no fuse you more than likely destroyed that board. Take the casing apart (the part attached to the boat) it should be two halves. That inital board you see is probably what is destroyed. Of course before i did that I would look for an inline fuse near where the cables attach to the battery or under the unit in the nose of the boat. There is nearly always a fuse if it came from the factory or dealership with the unit so i'd play a little extra hide and go seek for that before doing anything else.
Best of Luck
Jun 02, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
May 26, 2009 | Lowrance X96 200khz Fishfinder
Bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
May 06, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
My brother inlaw got a minkota 40ta all terraine trolling motor that is supposed to produce 40 pounds of thrust. it does not seem to produce even close to that. is it possible that the motor is turning the...
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
Apr 18, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
The plastic part in my bow mount Turbo 765MX(36lb.thrust) Minkota
Hello poorjohn, stroll to www.minnkotamotors.com/index.asp When you call ask for ext #406 and ask for Dave. Refer to my logon 'themoneypitt' He is a great guy. Merry Christmas.
Nov 21, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Lowrance X96 200khz Fishfinder Logo
80 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
