Question about Flotec 1/4 Horsepower Sink Pump System
FLOTEC MOD # FPOS1800LTS-08 LEAK
My Flotec MOD # FPOS1800LTS-08 leaks from the rubber grommet on top. The 2 wires coming through the grommet when wiggled causes unit to work at times. The S-trap under the sink feeding into the pump also leaks. (I mentioned this only if it may be related but I don't think so).
  • steveonorato Jun 03, 2010
    Sounds like need to replace entire unit.
  • 12,061 Answers
It actually sounds like you really need an entire nw unit. I fear that this existing one, is beyond repair, you would have to remake the connections through the grommet, and the grommet too. I guess you could remove it and try and refurbish it. replace the wiring to the motor. reassemble and reinstall.
Posted on Jun 02, 2010
How do I stop leak on Flotec FP4012-10? I tried to post a picture but website is experiencing issues.
depends on where the leak is . many times they can not be fixed and only can be stopped by total replacement
Apr 09, 2016 | Flotec Plumbing
My flotec pt4012 shallow well 1/2hp is leaking water from the pump. please help. It's a yr old
Usually it is the pump shaft seal located where the motor shaft turns the pump. It consists of two ceramic faces that are held together with a spring:
images?q=tbn:and9gcsqhemjvhz47gerqjd8xbjrm6rs_krzskup94w7_irt2dnk22eh
Feb 01, 2015 | Flotec Plumbing
Pump was fine but now turns on and off after just seconds of use. What could be the problem?
could be a short in the wire or A short in the switch itself or the motor is just bad
Oct 25, 2014 | Flotec Plumbing
Flotec pump fp4322 08
Try putting news print below it, be sure it is dry, then check later and you will shortly find the area the leak is located.
Aug 02, 2013 | General Water Leak Detector - WA500
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Aug 03, 2012 | Flotec Plumbing
Have Flotec pressure tank style fp7120-08 .Pressure gauge with nothing running goes up and down constantly. I've drained the water in house shut off power to holding tank znd there is no pressure
check the foot valve for leaks it at the end of the pipe in the well also if its newer than 30 years there is a cupler where the horizontal pipe meets the vertical on at the well head
Apr 24, 2012 | Plumbing
Flotec Model FP4012-D8 stopped pumping water. I took pump apart except for small impeller housing edge break I can see no reason for no suction?????
Hi jandh40...
You have an air leak somewhere in your piping, housing of the pump or maybe the mechanical seal and that is causing your pump not to pump.
Try to disconnect the piping and hook a water hose up to the pump and turn the pressure on, it should show you where the air leak is by spraying water out of the leak area.
Please take time to rate me
Aug 15, 2011 | Flotec Corrosion Resistant Shallow Well...
My dog chewed the power cord off my FPOS1800A-08 submersible pump, From whom do I order a new cord.
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
http://www.flotecpump.com/
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
Nov 14, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
I have a flotec fp512. It keeps loosing its prime in about 1 1/2 - 2 hours. after I shut the power off . its drawing from a creek about 20 feet away . there is a new foot valve at the end of the draw...
If the new foot valve is operting properly, then you must have a suction leak. If you can't find anything in the piping, then carefully re-inspect the check valve and where it attaches to the piping. If you still don't see anything, It is possible the pump seal is beginning to leak slightly when it's off, allowing air to enter the system. You could add another check valve near the pump, but it isn't necessary if all is working.
Aug 19, 2010 | Garden
No more then 30 pounds of presure and wont shut off. Flotec water
If the pressure does not get pass 30 psi, then check for leaks along the pipelines and on the tank itself. An air leak on the top portion of the tank can cause the pressure not to trigger the pressure switch. Use soap bubbles to detect any air leak. Although a stuck pressure is not more likely the problem, check it also.
Aug 31, 2009 | Flotec 1/2 Hp Stainless Steel Waterfall...
Flotec 1/4 Horsepower Sink Pump System Logo
462 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
