Question about Nokia 1112 Cellular Phone
I cannot open the sec code of my cp - Nokia 1112 Cellular Phone
S90,1997, Fualt codes : PO440 & PO358
PO440= Canister purge (CP) valve, leakage
Possible Source(s)
Blocked EVAP canister.
Blocked hoses.
Defective canister purge (CP) valve (permanently open or closed).
Code 0358 has no listing ??
Sep 17, 2011 | 1997 Volvo S90
Tip
Samsung SGH-500 codes
#*6837# = Official Software version
*#9999# = Software version
*#8888# = HW version
*#8377466# = Same HW/SW version thing
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = Check Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got ********)
#*7683# = Sleep variable (
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#8999*8376263# = HW ver, SW ver and Build Date
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*6428# = MIC Measurement
#*3230# = Trace enable and DCD disable
#*3231# = Trace disable and DCD enable
#*3232# = Current Mode
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages
*663867# = Dump Mm file
#*536961# = WAPSAR enable / HTTP disable
#*536962# = WAPSAR disable / HTTP enable
#*536963# = Serial eable / Others disable
#*53696# = Java Download Mode
#*5663351# = Wap Model ID [Your Model]
#*5663352# = Wap Model ID [SEC-SGHXXXX/1.0]
#*566335# = Wap Model ID [SEC-SGHXXXX/1.0]
*2767*66335# = Check on which model it is
*2767*7100# = SEC-SGHS100/1.0
*2767*8200# = SEC-SGHV200/1.0
*2767*7300# = SEC-SGHS300/1.0
*2767*7650# = Nokia7650/1.0
*2767*2877368# = Reset WAP Model ID to standard
on Mar 06, 2010 | Cell Phones
I'm looking sim lock code for my samsung d600e...\r\nplease help me.... thanks
Here's the list of codes
enjoy and dont forget to rate...
*#1111# ------------------ S/w Version
*#1234# ------------------ Dev.Version FW
*#2222# ------------------ H/w Version Rev
*#0206*8376263# ------ S/w Version ,Dev.Version FW,H/w Version Rev,time and Month and year flash *#0206*8378# ---------- Test Mode
*#4777*8665# ---------- GPRS Tool
*#0206*523# ------------ brightness of the display of 1-5
*#7465625# -------------- Interrogate - indication locks
*#0206*377# ------------ Error -- Table errors
*#0206*327# ------------ EEP(01/10)
*#0206*667# ------------ Debug mode
*#92782# ----------------- User agent (samsung-Sgh-G600/G600XEGH3)
*#232337# --------------- bluetooth addrnap uap lap
*#28837# ----------------- S/w Version BT and H/w Version BT
*#288378# --------------- Bluetooth Test
*#56658378# ------------ Look Test (Bomba code in a well-meaning words)
*#638738# --------------- Profiles Gprs- Inet settings (choice of various countries)
*#36245# ----------------- Test Mode (e-mail, mms, etc.)
*#0206*3768665# ------ DRM Tool (java, etc.)
*#777324# --------------- PPP TEST Menu
*#0673# ------------------ Mp3 Test Menu
*#0206*6366# ---------- Memo test
*#4378378# ------------- Gfs test
*#7378378# ------------- RESours Test
*#688# -------------------- Vod Test
*#64898378# ------------ NITZ test mode
*#898378# --------------- Timezone test mode
*#875108# --------------- FM Radio- speaker volume 1-10
*#52828378# ------------ Java Test Menu
*#73887# ----------------- Setup Wizard: (off/on)
*#2769737# -------------- Browser Test Menu
*2767*8451# ------------- Reset
*#738277# ---------------- Auto Profile Setting ( on/off)
*#0206*8376263# ------ S / w Version, Dev.Version FW, H / w Version Rev, time and Month and year flash
*#0206*8378# ----------- Audio Settings [menu (2) H / W test]*2767*688# = Unlocking Code
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*7271# = Multi Slot (Class 1 GPRS)
#*7276# = Dunno
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call ???
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# = ???
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*5663352# = Wap Model ID [SEC-SGH***X/1.0]
#*566335# = Wap Model ID [SEC-SGH***X/1.0]
*2767*2877368# = Reset WAP Model ID to standart
Jan 14, 2011 | Samsung SGH-D600 Cellular Phone
I NEED A NETWORK CODE TO UNLOCK MY D500 PHONE
Here are all known special codes for Samsung phones!
#*5737425# = JAVA Something{I choose 2 and it chrashed}][/b]
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*2565# = ChAeck Blocking
#*7276# = Dunno
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call ???
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# = ???
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7683# = Sleep variable (8)
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
~KenjiFox
Jan 07, 2011 | Samsung SGH-D500 Cellular Phone
How to unclock my samsung cell phone
ALL SAMSUNG UNLOCK CODE.... ---------------------------
*2767*688# = Unlocking Code *#8999*8378# = All in one Code *#4777*8665# = GPSR Tool *#8999*523# = LCD Brightness *#8999*3825523# = External Display *#8999*377# = Errors #*5737425# = JAVA Something{I choose 2 and it chrashed}]/b *#2255# = Call List
#*536961# = Java Status Code #*536962# = Java Status Code #*536963# = Java Status Code #*53696# = Java Status Code
#*1200# = AFC DAC Val #*1300# = IMEI #*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts. #*2565# = ChAeck Blocking #*3353# = Check Code #*3837# = ??? White for 15 secs than restarts. #*3849# = ??? White for 15 secs than restarts. #*3851# = ??? White for 15 secs than restarts. #*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM) #*7224# = I Got !! ERROR !! #*7252# = Oparation Typ (Class B GPRS) #*7271# = Multi Slot (Class 1 GPRS) #*7274# = Multi Slot (Class 4 GPRS) #*7276# = Dunno #*7337# = EEPROM Reset (Unlock and Resets Wap Settings) #*2787# = CRTP ON/OFF #*3737# = L1 Dbg data #*5133# = L1 Dbg data #*7288# = GPRS Attached #*7287# = GPRS Detached #*7666# = SrCell Data #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while) #*7284# = Class : B,C or GPRS #*2256# = Calibration Info #*2286# = Battery Data #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10) #*2679# = Copycat feature (Activate or Deactivate) #*3940# = External loop test 9600 bps #*4263# = Handsfree mode (Activate or Deactivate) #*4700# = Half Rate (Activate or Deactivate) #*7352# = BVMC Reg value #*8462# = Sleeptime #*2558# = Time ON #*3370# = EFR (Activate or Deactivate) #*3941# = External looptest 115200 bps #*5176# = L1 Sleep #*7462# = SIM phase #*7983# = Voltage/Frequenci (Activate or Deactivate) #*7986# = Voltage (Activate or Deactivate) #*8466# = Old time #*2255# = Call ??? #*5187# = L1C2G trace (Activate or Deactivate) #*5376# = ??? White for 15 secs than restarts. #*6837# = Official Software Version #*7524# = KCGPRS #*7562# = LOCI GPRS #*7638# = RLC allways open ended TBF (Activate or Deactivate) #*7632# = Sleep mode Debug #*7673# = Sleep mode RESET #*2337# = Permanent Registration Beep #*2474# = ??? #*2834# = Audio Path #*3270# = DCS support (Activate or Deactivate) #*3282# = Data (Activate or Deactivate) #*3476# = EGSM (Activate or Deactivate) #*3676# = Flash volume formated #*4760# = GSM (Activate or Deactivate) #*4864# = Dunno doesn't work on newer versions #*5171# = L1P1 #*5172# = L1P2 #*5173# = L1P3 #*7326# = Accessory (I got ********) #*7683# = Sleep variable (8) #*7762# = SMS Brearer CS (Activate or Deactivate) #*8465# = Time in L1 #*9795# = wtls key #*2252# = Current CAL #*2836# = AVDDSS Management (Activate or Deactivate) #*3877# = Dump of SPY trace #*7728# = RSAV done# (Everything went to standart but nothing was deleted) #*2677# = ARM State (None or Full Rate) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing ------------------------------------------------------- WORKS *#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF ----------------------------------------------------- WORKS*2767*3855# = E2P Full Reset WORKS*2767*2878# =SOFTWARE VERSIONS *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset #*6420# = MIC Off #*6421# = MIC On #*6422# = MIC Data #*6428# = MIC Measurement #*3230# = Trace enable and DCD disable #*3231# = Trace disable and DCD enable #*3232# = Current Mode
#7263867# = RAM Dump (On or Off) *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages *663867# = Dump Mm file #*536961# = WAPSAR enable / HTTP disable #*536962# = WAPSAR disable / HTTP enable #*536963# = Serial eable / Others disable #*53696# = Java Download Mode #*5663351# = Wap Model ID [Your Model] #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0] #*566335# = Wap Model ID [SEC-SGHXXXX/1.0] *2767*66335# = Check on which model it is *2767*7100# = SEC-SGHS100/1.0 *2767*8200# = SEC-SGHV200/1.0 *2767*7300# = SEC-SGHS300/1.0 *2767*7650# = Nokia7650/1.0 *2767*2877368# = Reset WAP Model ID to standart
Jun 15, 2010 | Samsung SGH-A877 Impression Cell Phone
I need a network unlock code for my sgh t401 samsung slider phoneit keeps saying sim locked code 1 every time I enter a new sim card in it...Can you help me?
Try this codes:Samsung T309 and T809 100%
1st Make Full Eprom Reset *2767*3855#
After Rebooting Mobile
then enter...
*7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
#7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
*#7465625#
T209, X100, X495, X660, D600, E780, T319
Input *#7465625# to check the locks....all locks should now be inactive as shown below:
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
T809 now with this procedure.
with t-mobile sim doesnt work.....
with wrong card it works.
procedure
1. enter *7465625*638*00000000*00000000# then turn your unit off. and power on again.
2. enter #7465625*638*00000000# then power off again. power on again .
full list of D500 secret codes (same as on E800)
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*2562# = White for 15 secs than restarts.
#*3837# = White for 15 secs than restarts.
#*3849# = White for 15 secs than restarts.
#*3851# = White for 15 secs than restarts.
#*3876# = White for 15 secs than restarts.
#*7276# = Dunno
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call
#*5376# = White for 15 secs than restarts.
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# =
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7683# = Sleep variable (Cool
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
*2767*2877368# = Reset WAP Model reset
Format samsung I300
1. turn off the mobile.
2. Press (0) + power button.
3. show screen Enter password
then enter master password like (1234)
now your mobile was formated
e860 & e530
E530 Unlock Method By Code
IF UR FONE WITH WRONG CARD!!!!!!!!! THAN STEP1
STEP1>>>>>>>press *#9998*3323# then press exit and slect 6
the phone is unlock then press *0141#
IF UR FONE WITH SIM LOCK THAN STEP 2
STEP 2 >>>>>>>PUT MOTROLA TEST CARD GO IN SECURITY AND THAN SIMLOCK AND THAN DISABLE AND ENTER CODE 00000000
THAN WITH WRONG SIM CARD DO STEP 1
GSM_BLUE
17th Oct '07 Wed, 18:27
mga boss eto try nyo sa mga wala pa. im sure wala pa nito dito kasi nag seach ako wala ako makuha. para mga walang cable! hehehe
Samsung X660
Turn off the phone. Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7.
After phone reboots type *0141# and t the Call button. Turn off and insert another SIM Card. Turn on. The code is 00000000.
GSM_BLUE
17th Oct '07 Wed, 19:05
!!!!Unlocking V804ss thru codes!!!!
To all who want to maintain as japanese version for V804ss and Z540 without flashing just do the following:
Take out SIM CARD
Press: *7465625*228#
Power off. Put your SIM CARD.
Jan 13, 2010 | Samsung Cell Phones
Samsung t239 wrong card message
samsung all code press unlock
here are the codes that i have hope they help
D807
Guys!!! :-) Unlock D807 - Its so easy!!!
Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another SIM Card. Turn on.
e900
Free solution (SIM)unlock E900
Here follows the free solution to (SIM)unlock a Samsung E900, which worked for me.
- NSdongle crack + D800 USB datacable (PCB120BBE)
- Select C200 model
- Select right COM port (Windows XP -> Devicemanager -> Ports (COM&LPT))
(Not the COM port which you can find under 'Modems')
- Press 'UNLOCK'
And your Samsung E900 is unlock! (Well, mine was)
(Thanks!! to BouRRi GSM, who wrote it somewhere on this forum)
Got
new sam unlock
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
sp lock - inactive
cp lock - inactive
sim lock - inactive
auto sim lock – inactive
panamastercodes
*01763*737381#
sam1
Power on your phone (Models Z105, Z107V, Z140, Z140V, Z500, Z500V, etc.......)
1- Enter code *7465625*28782# without a sim in the phone
2- Phone will display "Auto Subset Lock: Activated!"
3- Enter code *7465625*28638# without a sim again
3- Phone will display "Auto Network Lock: Activated!"
4- Now insert the sim and enjoy! Phone is Unlocked!
(NOTE: When you change sim to other operator
repeat this process to unlock it for that operator also)
sammaster
*2767*2878# without simcard
Samsung
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*7276# = Dunno
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call ???
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# = ???
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
*2767*2877368# = Reset WAP Model ID to standart __________________
Jan 08, 2010 | Samsung SGH-t239 Cell Phone
Want to do a factory reset on my samsung e250
here are all codes for E250,
enjoy and dont forget to rate it as it will fix the issue.
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*7276# = Dunno
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call ???
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# = ???
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
regards
Apr 08, 2009 | O2 Samsung SGH-E250 Cellular Phone
Security code problem
im balwinder i have a problem about my cellphone can you find my security code for me?i can't open my cellphone because of security code ..0000 is not working. can you give me some other codes..please help me.. my cp model is KG220 thank you,
May 19, 2008 | LG KG220 Cellular Phone
Nokia 1112 Cellular Phone Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
