Question about Proform Exercise & Fitness
Belt squeaking and hesitating when I run
I have a Pro Form 770 EKG Treadmill. It has started squeaking when I run and occasionally hesitates when my foot lands and throws me off balance. Do I need to lube it? If so, how and with what?
    President:
  • Proform Master
  • 832 Answers
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust. Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts. Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5. Step 4- If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5. Step 5- If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced. Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position
Posted on Jun 03, 2010
Tighten belt on proform 770 ekg treadmill model no 291661
see the video attached, and follow the step. God bless you
Oct 22, 2013 | Epic View 550 Treadmill
My Treadmill PROFORM 760 EKG will just stop as I am walking on it.
see the video and proceed according. Lube the rollers front and rear, test the drive belt motor and replace.
God bless you
Jun 16, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
My Proform 770 EKG treadmill's motor is overheating. What is the voltage that should be pulled during use? Should the walking belt be replaced if we replace the motor?
see the video and lube correctly. 2) go to my personal TIPS for motor help.3) however you must see the voltage in the plate of motor. the tolerance will be +- 10% of voltage. can be voltage continuosly or alternating voltage.God bless you6527db9f-a9f8-47a6-9208-af2b680ea3a0.jpg
Apr 01, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
Belt stops during workout and have to step offf
you need LUBE in according with the instruction manual maintenance schedule . You have a deck belt worn 2) Test the drive Belt for replace 3) Test the input voltage motor, if there are the motor need repair 4) Test the output voltage from motor board, for input main motor, if there are NOT the board is faulty.
RUN the software calibration for easy diagnose and troubleshooting. See my personal TIPS for HELP.
sincerely. God bless you
Apr 27, 2012 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
My Pro-Form 770 EKG changes speed without direction from users. Any?
HI,
You have to check the speed sensor near the mottor pully. If the speed sensor is fulty or if its coverd with dust then speed can vary. Another reson for speed variation is the Faulty carbon brush in the motor. I have added the picture of speed sensor for reffarance . Also the link will help you for the regular maintenance of the treadmill.
How to repair treadmill
Ajin
Feb 27, 2012 | Exercise & Fitness
Is there a weight limit on the Pro-Form 760 EKG treadmill? While I am walking the belt skips and I feel like I am going to fall.
not sure if there is a weight limit but did you check the belt tension.
front or rear roller should have an adjustment screw on both sides to tighten the belt. this could be the solution to your problem
Aug 24, 2011 | Proform 760 CrossTrainer Treadmill
I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Dec 29, 2009 | Exercise & Fitness
Exercise & Fitness Logo
1,300 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
