Question about Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook
No drive detected
All of a sudden today, my Dell Insprion E1705 froze and then went to "disk error". It gives me error code 2000-0141, which is "no drive detected". I cannot get it to recognize the hard drive. What can I do?
  • 1 more comment
  • koko2004 Apr 09, 2008
    I tried pressing delete whn starting up, but it just gives me multiple "disk error" messages. When I was able to run diagnostics, it said it could not find the hard drive.
    I don't have an extra SATA hdd, so I guess I am going to have to pay an exorbitant sum to have someone do all this.
    I have confirmed the death of my hard drive. I have a replacement to install, which I will tackle tonight. I found out why it happened...I moved my laptop from my study to the kitchen without first turning it off. Apparently that kind of movement can cause your hard drive to crash. Thank goodness I have been using Carbonite.
  • 77 Answers
Try inserting another SATA hdd (hope you have an extra) and see if your laptop computer detects it or not.
if it does, then your old hdd is confirmed to have totally crashed
if it does not detect still, then you are faced with a bigger problem which is the board.
Posted on Apr 09, 2008
  • Philip Tan
    Philip Tan Apr 09, 2008
    By the way.
    Accessing the bios for the Dell inspiron 1705 you need to press F2 upon boot up and not DEL key.
  • 871 Answers
Hey koko
can you try to restart your laptop and try to go into BIOS..
press delete when your laptop is starting up.
when your already in BIOS, look for the booting sequence. you must determine that your harddrive is recognized at this point and make it a primary boot.
post back for any more questions ok.
SOURCE:
Dell insprion 5315 error code0f00:0244
This looks like a problem with your hard drive. Have you tried running any disk check software to make sure that the data on the disk is not corrupt?
Oct 17, 2013 | Dell Inspiron 531s Desktop Computer
Error message: Pri Slave Hard disk A S.M.A.R.T. ERROR has ben detected
Your hard disk might be dead due to sudden power cut or may be a shock on the hard disk while it was working due to an accidental hit on the c.p.u. You can give it to a computer mechanic to test the drive if its working or not. If not then you may check its warranty period and if its over you have no other option than replacing it. I also had the same problem with my hard disk.
Oct 14, 2011 | Dell Dimension 4500 PC Desktop
I get an Error message:Pri Slave Hard Disk A S.M.A.R.T.error has been detected? What is this message and how do I fix IT? Thanks Dan
Oct 14, 2011 | Dell Computers & Internet
Dell insprion N4010 error code 2000-0146 My computer become very very slow. And windows media also not start.
This usually indicates a hard disk self test failure or impending failure. Before anything I would back up your files.
If under warranty I would call Dell support.
Simple answer I would get the drive replaced.
Sep 25, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have a Dell Inspirion E1705 which came installed with Windows XP. When I turn the computer on, I get the Dell Logo, then nothing except a cursor in the top left side. I tried booting from the...
try this, while the computer is off, press and hold the Fn key down then press the power button like turning it on.. it should say diagnostics boot selected. if it passes the test windows would have to be reinstalled. if it fails with error codes 0141, 0142, 0143 or 0146 then the hard drive has to be replaced.
Nov 11, 2010 | Dell Inspiron E1705 Notebook
What does error 2000 - 0141 device not detected mean on my Dell Inspiron E1705?
Hi try the following link for some very helpfull information:
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Jul 23, 2010 | Dell Inspiron E1705, Intel Core 2 Duo...
Dell Inspiron Error Msg 2000-0141 cannot detect Hard Drive
You might have a hard drive crash, Meaning the hard drive needs to be changed out in it.
This happends over time,heat,AGE and all other sorts of occurances. Hard drives to not last! period! The only fix here is to have the hard drive replaced with new. Now in this model the hard drive should be on the bottem of the unit under a cover. you take a screw driver and open that hatch and take the hard drive out. You can bring that to a local best buy or computer shop and have a replacement put in Around $89-150 bucks depending on size you get and brand.
Thanks I hope this helps you out please do be considerate and leave postive feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 14, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook Logo
582 people viewed this question
Ekse
Clive
Clive
