Question about Magellan MAESTRO 3100 98083401 GPS Device
Need help adjusting my screen. It is off by approximately 1/2 inch.
    President:
  • 1,111 Answers
Scroll to the user options menu, then system settings, then tap the next tab at bottom right, then go to the diagnostics tab, then touchscreen test and follow the instructions on the screen.
if you need further help, just post back to me
Bill
Posted on Jun 14, 2010
  • jlatkyjohn Aug 21, 2011
    My maestro 3100 did the same thing. I went to the Disgnosis screen and after 10 minutes of chasing the target around the screen; I gave up. What next?
  • Ben Dover Aug 21, 2011
    do you have the 2.18 update in it?
Cme 506 cubes too small
turn ice bridge thickness screw clockwise to thicken and counterclockwise to get thinner. Do not turn anymore than about 1/8 turn between freeze cycles. the adjustment screw is very finicky and requires patience in setting properly. the distance from the bridge thickness gauge to freeze platen is approximately 1/4 - 5/16 of an inch.
Nov 20, 2012 | Scotsman Ice Machine, Cuber, 1825 lb....
Will a 80 x 80 CPU fan/heatsink fit on a XFX GeForce 8200 motherboard?
Not to sound trite, but measure the distance.
70mm = 2.755 (Approximately. It is actually 2.755905511814)
80mm = 3.149 (Approximately. It is actually 3.149606299216)
Get out your digital caliper.
OH, I'M JUST KIDDING!
70mm is approximately 2 and 3/4 Inches.
80mm is approximately 3 and 5/32 Inches.
Measure to see, if there is around another 9/16ths of an Inch, on all 4 sides.
(1/16th past a 1/2 inch)
If so you've got it made!
Regards,
joecoolvette
(Watch the capacitors on the motherboard, choke coils, etc. Make sure you take all electronic components, on that motherboard into consideration )
Jul 29, 2012 | Computers & Internet
I am searching for a 78 inch shopmaster band saw blade?
You might be able to make an 80" blade work if you have enough adjustment. Here are some 80" blades from Grizzly. http://www.grizzly.com/products/category/165996
Good luck
Jun 01, 2012 | Saws
Have a 4 yr old 32" samsung flat screen. The screen recently has an approximately 1/4 inch wide line going horizontally across the entire screen and more recently a second line of approximately 1/3 of...
It can be costly and difficult to replace the internals of any flatscreen television screen. Your best bet is to consult an electronics professional in your area for an estimate in repairs.
If you are a technically inclined person and you've got nothing to lose, you could always try ordering a new board online and attempting an install on your own.
Take a look at NewEgg, they usually have a good deal now and again on electronics parts, televisions included.
http://www.newegg.com/
Jun 14, 2011 | Samsung LN32C530 32 in. TV
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
There is a scratch on the screen and it's getting bigger, well it was scratched now there is a solid colored line. What do I need to do? Is it fixable? It started as a scratch about 1/2 inch now there is a...
Unfortunately it is NOT a "Scratch"... actually it is one of the "Row Driving IC's" that is failed/failing, this will only get worse and eventually it will get more & more. Worst of all there isn't anything that can be done, sorry.
Feb 16, 2010 | LG 42PC3D 42 in. Plasma Television
Ksrg25fkss kitchenaid refrig door needs height adjusted up
Have you looked at the mounting bracket for the lower hinge to see if it can be adjusted up. If not and there is as mush as 1/4 to 1/2" adjustment i suggest that you get a spacer with the inside diameter the same as the hinge pin or a tiny bit bigger and cut it to the size you need , then support the door up to a point that the bottom pin is not bound, remove the lower bracket and hinge pin, put the sleeve you cut on the hinge pin and reinstall the bracket.
Jul 28, 2009 | Refrigerators
The horizontal is out of adjustment
open ur tv and find the 100uf/35v and change it.
May 08, 2008 | Hitachi 43FDX01B TV
HDLP61W151YX2 Aperture
There should be some adjustments on the smaller mirror to offset any misalignments on the screen itself. It may use a allen wrench possibly. sometimes a phillips screwdriver also. Let me know if this helped you . Thank you Jay.
Jan 30, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Magellan MAESTRO 3100 98083401 GPS Device Logo
106 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
