...shows the iPod-specific connector on the JVC is just USB, so I must conclude you have lost the iPod USB cable, not a cable that is unique to this product.
THAT would be found under an iPod request. Google "ipod usb cable" or look around on eBay.
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the manual because they want you to purchase expensive accessories like docking stations.
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This
optional iPod Interface Adapter supports audio playback for the following
iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini
(1st/2nd gen), iPod nano
(1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic
(80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd
gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge
the iPod nano (4th generation). *Apple firmware updates may change
functionality results.
you can hook up ipod 2 different ways. the one i will use will be with a 3.5 to 3.5 mini plug connection(on both sides of cable it has i.e. head phone jack connection) and then set unit to aux in and that will give you sound from ipod. another way is with red and white audio cables to 3.5 mini plug connection. connect red and white to audio in on back of unit,and then set unit to that source.
If you got keys that came with it just slide these down the side, if not just take of the face plate and slide to flat headed screw drivers down the side. it wont damage it.
Just installed a 'generic' KS-U57 (same as the KS-U58, but terminates in a RCA, $7 on ebay) that has the same black box--except I cracked the black box open and found that it is empty (only contains soldered connections). I imagine that the authentic JVC is the same.
I have a noise problem (engine static), but it is because my mp3 player is charged by the cigarette lighter--unplugging it eliminates the noise, so as far as I can tell, there is no need for a noise filter inside the KS-U57.
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
