Question about Samsung RS265LABP Side by Side Refrigerator
Leaking water from inside lower drawer - Samsung RS265LABP Side by Side Refrigerator
  • 4,059 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jun 02, 2010
Fisher paykel dd605
F1 (or E1) is a "Flood" fault and means there is water in the bottom pan. This is beneath the bottom drawer. The sensor is in the left, rear corner of the base pan. Any kind of leak, including over sudsing or split hoses or or lid not down fully due to tall items in tub, can cause this. Remove the lower drawer, dry the water from the pan bottom, reinstall the lower drawer and check operation. If this error recurs you must find the leak and correct it.
Sep 26, 2016 | Fisher and Paykel Dishwashers
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Hi i have 2 door showing F1 WHAT does itmein
That means you had a leak and the under the lower drawer has taken on water. Remove the lower drawer and remove the water. Then locate why your drawer was leaking n the first place. Did you have too tall of an item in it, or did you use the incorrect soap? Normally its a tall item that caused the leak.
Good Luck
Sep 09, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Hi I have a Hotpoint Ultima 6kg WMA 76 washing machine - had for 6/7yrs. It has just started leaking water from the drawer when it changes from the wash cycle to the spin cycle...have given the drawer and...
You need to check the pump filter, and clean same.
Remove lower rear cover, locate and remove large black hose, remove and clean filter inside hose.
Please rate my solutioon.
Thanks.
Jul 26, 2009 | Washing Machines
Fisher and Paykel Dishdrawer beeping constantly
leave it unpluged to stop for now, the machine has detected a leak and is constantly running hte pumps within the drawers to try to remove any water.. problrm is the water detector is in bottom under the lower drawer and htere is no pump to remove that water ..canbge a fickle machine as far as leaks are concerned, but the easy reason is usually misloading of the drawer itself, was an item put in that was too tall , preventing the lid from coming down and sealing off drawer causing water to overflow down the side??? there should be(so logn as no previous repairmen have taken it) a tech/trubleshooing guide taped to teh back wall behind the lower drawer, which is easily removed by unlocking hte hinges on either side of the front of drawer, explained in your manual
Nov 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water leak from detergent drawer
Remove the control panel. Inside you will find a service tech sheet that will identify the error code.
There may be an obstruction in the water valve inlet flume forcing the water to travel in the wrong direction.
Jan 05, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Samsung RS265LABP Side by Side Refrigerator Logo
216 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
