Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
It will not drain , the screen is clogged from the inside, i took it apart , and the round screen doesn't seem to open to get it cleaned. how do I open it?
  • 4,059 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jun 02, 2010
My dishwasher is having trouble draining, how do i fix this?
Natalie, there are two major causes of this condition: first look at and clean all filters. Too much particulate matter clogs screens.
Also, check that the drain hose is not kinked.
Jan 26, 2015 | Dishwashers
Dishwasher 15701
Is it a new install? If so check the drain inlet under the sink. There is a round plug in the drain ( if it's new ) where the dishwasher drain line connects to the pic pipe under your sink.( use screw driver to pop it inward don't worry it won't clog your drain )
If it's not a new install the drain pump may just be worn out. Or the butterfly valve above the pump may not be opening. Manually open this valve, using a screw driver while it's running spin the dial until it's in drain mode. You will see a solenoid that pops up and down connected to the butterfly. Use the screwdriver to push the valve lever open all the way. Usually downward. hope this helps.
Apr 08, 2014 | Kenmore Dishwashers
Drain pump isn't working properly or mystery clog
I would replace the drain pump if you are sure there are no obstructions to the water flow.
May 19, 2017 | Washing Machines
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
My VW GTI has an interior water leak. Can't find it, but the rear passenger side is full of water?
Two areas to check. The sunroof has several drains that can clog. Open the sunroof and look in the four corners. You will see small holes. Try flushing water down each one with like a cooking baster or spray bottle. If that won't clear a clog use a long wire but with a rounded end. You could cut rubber parts if the end was sharp. The second area is in the door panel area. Each door should have drains in the bottom. If they are clogged it will overflow into the interior. Also if that door has been serviced and the moisture barrier was not reinstalled correctly you will get some water leaking inside.
Feb 08, 2010 | 2003 Volkswagen GTI
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Drain is clogged
I had a flashing red Intake/Drain light. After calling Miele tech support, he confirmed that the drain was plugged so I took all drain hoses apart and finally discovered that the problem was a plugged air gap. I replaced it and the problem was solved.
Nov 18, 2009 | Miele Dishwashers
Washer won't drain -- clean the pump
First I would try to flush the pump, if the tub is still full of water. To flush the pump, take a garden hose sprayer and fit it tight into the drain hose. Give it a short shot of water, then stick the drain hose back into the drain. Put the washer on spin and see if any water comes out. You may have to do this more than once to clear the pump. If that does not work, siphon the water out of the washer and disconnect the hose from the pump to the drum. Clear the hose the best you can, pour a little water into the drum to check it. Check the pump too, take it apart if you have to.
May 05, 2009 | Washing Machines
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
146 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
