Question about HP Pavilion dv7-1130us laptop
Why does my laptop freeze and then show different colors?
    Sergeant:
    Champion:
  • 452 Answers
The video chip is acting up. If still under warranty contact HP. If out of warranty you can try this DIY repair guide from www.msbin.com
Posted on Jun 02, 2010
It freezes showing different colors and sometime shuts off
Hard drive is going; or CPU is overheating; or Video card is bad:
Jan 11, 2013 | Computers & Internet
Compag laptop connected to LG HD TV. TV screen just show blues and greens, no reds. What do I need to do
To troubleshoot this, you must first start with the obvious. Check your cable connections/try replacing the cable. If this does not work you should then check the color settings in the tv. If that still does not work you can try connecting your laptop to a different monitor/tv. If the color shows up with the same problem, you know the issue is contained within the computer itself. Possibly bad VGA/HDMI Port or color management settings.
Nov 18, 2010 | Compaq Computers & Internet
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
It will freeze up during a game
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
Feb 04, 2010 | Microsoft Xbox 360 Console
Display freeze then colors became crazy
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 10, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Toshiba laptop screen is flickering and showing different colors especially where green is showed on the screen
hello
This different color thing happen due to only loose connector, either at the LCD end or at the mother board end.
so if you have some experience with hardware you can open up and check the connectors and see if they have to be replaced or just need to fix properly.
Thank you
Aug 19, 2009 | Computers & Internet
Everytime I turn my PS3 on it gets past the sony entertainment screen the it gets to my background and freezes in a weird way (it has these small multi-colored rectangles come over my screen in a random...
It sounds like you hard drive is starting to crash. Try your HD in a different PS3 and see if it does the same thing. The HD in a PS3 is the same thing that is in a laptop computer and they go bad just like the laptops do.
Aug 02, 2009 | Video Game Consoles & Games
My laptop freezes with jagged diag lines showing on the monitor
try to re-install your video driver to its latest version.
Jul 01, 2009 | CMB T43 750 Notebook
Laptop screen freezes in different color
This is definately an over heat issue. since laptops use on onboard graphics card, chances are you might need to replace the mother board, or may it may just need a fan replacement. also purchase a laptop cooling pad
Jan 27, 2009 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 9810 Screen Problem
Hi No otto,
On the bottom row of keys, you will see one marked Fn, in a different color. Hodl that and look at your top row of keys. Should be one with a laptop screen, and a monitor. The little graphics will be the same color as the Fn key. Tap that once, wait, see if the screen comes to life. Usually that key is set to choose "Just laptop screen, just external monitor, or both", with each tap.
Good luck,
Jan 06, 2008 | Dell Inspiron 6000 Notebook
HP Pavilion dv7-1130us laptop Logo
88 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
