Question about HP Photosmart C5180 All-In-One InkJet Printer
Oxc18a0401 ink system has failed - HP Photosmart C5180 All-In-One InkJet Printer
  • HP Master
  • 1,684 Answers
The "Ink system failure" error is caused by air in the ink feed tubes. The happens if you allow the ink o fully run out of the cartridge and the printer sucks up air or you use a poorly filled ink cartridge with air bubbles. To clear the error you will need to perform a feed tube purge. This procedure takes about 10 minutes to complete. We have the step by step guide to do this posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This should get you back going.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Jun 02, 2010
5 Suggested Answers
shahabdun
  • 249 Answers
SOURCE: I REPLACED ALL MY INK CARTRIDGES AND STILL GET INK
problem with the ink reader/scanner.
Posted on Jul 17, 2009
sethdileswar
  • 253 Answers
SOURCE: hi my printer is displayinh oxc18a0401 ink system
change your cartridge or change your carriege assyembly
Posted on Apr 06, 2010
  • 1684 Answers
SOURCE: a ink system failure has occured oxc18a0401 i have
The 'ink system failure' error is caused by air in the ink feed tubes inside the printer. This problem is caused by either letting your ink run totally out in one or more cartridges or using poorly refilled cartridges. You will need to run a purge routine to flush the ink tubes of the air and clear the error message. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ that will walk you thru running the purge routine. It takes about 10 minutes to do but then your printer should be good as new.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 19, 2010
SOURCE: HP7180 ERROR OXC18A0401 INK SYSTEM
Without turning off the printer, disconnect the USB cable at the back of it.
Remove the cartridges and wait for the 'Insert Cartridges ' message to display on the control panel.
Disconnect the power cord from the back of the printer then wait 60 seconds and reconnect the power cord.
If the printer does not automatically turn on, press the Power button.
Reinsert the cartridges, and then close the cartridge door.
If it prompt you to print a calibration page, do so.
Reconnect the USB cable at the back of the printer, and then try printing again.
If the same error message appears on the front panel service your printer.
TNX
Posted on Apr 24, 2011
What do I do for a Oxc18a0401 failure
Hello and Welcome!
The error
Oxc18a0401 is mostly occurred in HP printers
To solve the error code
Oxc18a0401,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
Sir, If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Dec 14, 2011 | HP Office Equipment & Supplies
Hp photosmart6280 error oxc18a0401
hi
go to this site for error explanation. although the exact error is not listed, i do believe that cleanin the ink-jets is vitally important to resolve this problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=3382185
May 08, 2011 | HP Photosmart C6280 Printer
HP7180 ERROR OXC18A0401 INK SYSTEM HAS FAILED UNABLE TO COPY RECEIVED FAXES OR PRINT CAN YOU HELP ME? RO
TNX
Apr 23, 2011 | HP Photosmart C7180 All-In-One InkJet...
Ink System Failure Oxc18a0401 happened after I installed a new yellow HP ink cartrage. Have gone through pressing buttons according to instructions and cannot find a solution.
The ink system can fail if the cartridges in the printer are installed incorrectly, if the ink in the cartridge is low or out, or if the cartridges are damaged or not correctly vented. Follow these steps to check the cartridges thoroughly and resolve any issues you might find. Step one: Replace empty or low cartridges The error prevents you from checking ink levels using the HP software. However, this error can be caused by a low or empty cartridge. If the Ink Alert message displayed before the error occurred, replacing the cartridge might resolve the issue. Step two: Make sure the cartridges are installed correctly
  1. Turn on the product
  2. Lift the cartridge access door to open it.
  3. To remove the cartridge, press the tab on the front of the cartridge to release it, and then remove it from the slot.
    Do not leave the cartridges outside the printer longer than 30 minutes. Doing so can result in damage to both the printer and the cartridges.
  4. Examine the vent area, which is located on top of the cartridge, next to the HP logo. If an orange tab is attached to any cartridge, remove it.
  5. If any of the cartridges have clogged vents, use a pin to clean the vents.
  6. Using the colored shape icons for help, slide each cartridge into the correct empty slot, and then press down until the cartridge snaps firmly into place in the slot.
  7. Close the cartridge access door.
  8. Check the product control panel display.
Step three: Use the automatic printhead cleaning utility
REMARQUE: The automatic printhead cleaning utility is available only if you installed the HP software that came with your printer. Follow these steps to use the cleaning utility:
  1. Turn on the product, and then connect it to the computer.
  2. In the Windows system tray, double-click the HP Digital Imaging Monitor (DIM) icon ,HP Solution Center opens in a new window.
  3. In HP Solution Center, click Settings .
  4. Under Print Settings , click Printer Toolbox . The Printer Toolbox opens.
  5. Click Clean the Printhead , and then follow the on-screen instructions. The product prints a test page when the printhead cleaning completes.
  • If the print quality is acceptable on the test page then there is no need to continue to troubleshoot.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 04, 2011 | HP Photosmart 3310 Printer
A ink system failure has occured oxc18a0401 i have cleaned the ink tips but no joy please help ta
Buddy
Corporate Computer
www.ccl-la.com
Apr 18, 2010 | HP Photosmart C6100 All-In-One Printer
While using my HP C6280 printer it stopped working and the Ink System Failure oxc18a0401 appeared. It said to shut the printer off and turn it back on but this did not work. Prior to this error...
first off all disconnect the power cable from the surge protector or power stripe if any and connect it directly to the wall outlet
after that turn onn the printer try to make a copy
if you have solution center in your computer try to clean and allign the cartridges from the printer TOOL BOX in SOLUTION CENTER from your computer
still if it does not work follow the steps given in the url
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01125396&cc=us&lc=en&dlc=en&product=3194498
and if still you get the same error it is the problem with the ink system so if your printer is in warranty call hp they will replace it for you
Oct 16, 2009 | HP Photosmart 3210 Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
517 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
