Question about Craftsman Garden
Which Craftsman 2 hard bin bagger attachment Part # fits my Craftsman 917.256571 19HP 42 inch deck tractor? Thanks, Greg
SOURCE: Need diagram of deck linkage on Craftsman 42 inch
Go to sears parts direct and punch in your model #
Posted on Mar 27, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
Need help on installing a 2 bin hard bagger on a craftsman lt1000
call sears, and ask them to get you the manual.
Nov 20, 2011 | Garden
Have a Craftsman LT1000 and the discharge pipe on the grass collection tube continually gets clogged. The grass is not wet or overly thick and the blades are sharp. Engine RPS's good and i always cut...
Inspect the inside surface of the discharge tube. If you do not find any hangups, then I would wonder how fast you are mowing. If you are going full speed, I would recommend that you slow just a little. I was just thinking, have you been doing the same thing for a long time and recently have this problem develop. So, give good inspection. I do not know what type of bagger you have, but is the air able to escape the bagger, if it is not then it sets you up for a clog. If you can not find anything on detailed inspection of bagger system, there are sprays for under the deck of lawnmowers to minimize the chance of grass clinging to the underside of decks, you could try applying that to the ducting of your bagger. I hope this is helpful.
Aug 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I just purchased a poulan xt 38" riding mower and am wondering if this is the correct bagger for this. My model # is PXT12538.
If your tractor is 2006 or newer then yes this is supposed to fit. This bagger will also fit some craftsman mowers.
Jul 22, 2010 | Husqvarna #QCT38 960720001 38" Dual Bin...
Craftsman 42 inch belt diagram
look on deck or under foot pedal there is usually a diagram in those places
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Our craftsman garden tractor model no. 27603 doesnt fit a bagger!
ALL craftsman side-discharge tractors can accommodate a collector. If you can't get one specifically for your model, a universal one will fit.
It takes the form of a couple of plastic bins fitted to a frame that is mounted on the towing eye on the back of the tractor. A large diameter tube runs from an adapter 'boot' that fits over the discharge opening, to the bins on the back.
I'm in the UK, but we sell loads of these kits. SInce they come from the States, it shouldn't be a problem.
May 07, 2010 | Garden
Which snowblower attachments will fit my lh1000 42" craftsman lawn tractor
go sears web site, typ in your model number it well give you attachment part number if there is on emade for your unit. not LT can take blower attachments. its more likly you have a polune or AYP unit
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Jul 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
111 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
