Question about Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
  • 33 Answers
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
My water heater pilot light won't stay lit
I would try cleaning the thermo couple surfaces with some steel wool... Both where the flame contacts the sensor, and the electrical contacts. Even a small increase in voltage may be enough to hold the pilot valve open. Both black, and white soot on the sensor end, can act as an temperature insulator, lowering the output voltage.
As for finding the part numbers for replacement: http://www.reliancewaterheaters.com/media/48391/242117_RPPCR01111-Reliance-Parts-Catalog.pdf
Feb 17, 2016 | Water Water Heaters
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Laars pool heater's burner wont stay lit
Check the burner, the holes may be plugged, especially at the beginning of the season. Same happens to the pilot light tube. Spiders love to make nests inside those small holes clogging everything up.
Aug 13, 2014 | Teledyne Laars Pool & Spa
Pilot stays lite but burner won't ignite
you have either an open safety, poor wiring connection, or problem with tstat controls
Apr 15, 2014 | Zodiac Jandy Legacy LRZ 175K Commercial...
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
Jun 19, 2009 | Hayward H Series Millivolt 250,000 Btu...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas Logo
519 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
