Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp photosmart c6180
My printer said i was out of pink ink then i changed it but then it said all of them where out alwell. now it will not let me print or revice any faxs.
how can i print or fax? it will in some clours but not black.
No solution, but that's what mine did to! What is with the pink ink?
Posted on Apr 13, 2008
SOURCE:
How do I clean print heads on the HP photosmart printer. I am not getting any pink ink. I changed to cartraige, but still not pink.
go to control panel and select printers, right click on printer and select properties, click printing preferences, go to features tab and click printer services button, click clean printheads
Oct 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
How to change ink on C4700
power the printer on, next open the front panel, and the inks will slide to the centre, pick the inks cathridges out remove the pink paper on the new ones and replace them as you had removed them, close the lid, press okay on the LED screen and you are done
Jun 17, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180. I can't check ink level on my computer
Not all printers have this option, but i think this one should. you may need to download and install the software, you can do that from here: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=id〈=en&product=1153494
Try the HP Photosmart Full Feature Software and Drivers and the HP Printing Diagnostic Utility
give that a go. Hope this helps
Jan 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink and Print issues always says replace blk and yellow ink and printer says its ready to print but won't print on HP Photosmart C6180
If you have replaced them and it still says so than it is not reading the chip on the back of the cartridge. push and wiggle the cartridge and see if there is a change. If you do a lot of printing and are tired of getting screwed by HP look at the refillable carts on this page "http://www.inksupply.com/inkjet_cartridges.cfm?search_getmodel=982" . Just never use any other brand of ink. cheap ink will kill the printer.
Sep 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Can't use my original ink # 363
Actually you cannot use your # 363 ink on your photosmart c6180. The ink is not compatible with the printer. Photosmart c6180 only uses HP02 vivera inks. And there is no way that you can reconfigure it because it is factory default. Unless you bought an HP02 ink from other country outside US and bought the printer in US, that's the only time that we can reconfigure the regionalization of the printer
Aug 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
70 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
