Question about Food Mixers
I have a Sinmag 20 quart dough mixer. The bowl is
I have a Sinmag 20 quart dough mixer. The bowl is supposed to go up and down with a lever, but it is stuck in the upward position and when I move the lever the bowl dosen't lower. What can I do to fix it?
SOURCE: bosch universal mixer
Sounds like the belt came off when you tried to mix the frosting while it was cold. Just too much of a load. It will have to be taken apart and the belt put back on.
Posted on Aug 29, 2008
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
  • 145 Answers
SOURCE: Kitchenaid Mixer will not lock
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
Posted on Jul 08, 2009
  • 145 Answers
SOURCE: KitchenAid 600, Stand Mixer -
If the beater is grinding when it meets resistance, it generally indicates that an internal gear has broken or been stripped.
With the Professional 600 stand mixer, up to 14 cups of white flour or only 8 cups of any flour are recommended at one time. Speed 2 is the only speed that should be used for bread dough and it should never be kneaded for longer than 7 minutes. Failure to do any of these things make cause problems for the mixer motor.
If you are interested in self-repair, I recommend mendingshed.com. They have internal parts available to order and also have a .pdf file for the Kitchenaid Mixer Service Manual.
If you are interested in a repair facility, please visit the following link:
http://caservice.kitchenaid.com/
This is a listing of certified repair locations.
Also, if the mixer is less than a year old, Kitchenaid may replace it under their 1 Year Manufacturer's Warranty. I would recommend calling their customer service. Their toll-free telephone number is:
1.800.541.6390
Posted on Jul 16, 2009
supertech6
  • 513 Answers
SOURCE: I was making bred dough with the mixer and when
You have broken the intermediate gear in the head. This gear can be a bit of a problem to change. Here is the parts manual for the KSM150PS.
The part is probably #6, worm gear.
Check with Kitchenaid on where to buy parts.
Posted on Apr 21, 2010
How do I change the gear oil in a food service mixer sp62
About 49 results (0.77 seconds) Search Results
    [PDF]Instruction Manual for Globe Mixers - Globe Equipment ...
    https://globeequipment.com/media/product.../Sp10_Owners_Manual.pdf
    Or call the Globe service department at 937-297-7247 and ask for contact .... Please remember that this manual or the warning labels do not replace the need to be alert, to properly train and .... gears or other parts and WILL void the warranty! 7. ... Lubricate the attachment shaft with a food quality grease or mineral oil. 4.
    SP62P 60 Quart Pizza Mixer - Globe
    www.globefoodequip.com/.../mixers/...mixers.../sp62p-60-quart-pizza-m...
    This mixer comes complete with an 60 quart stainless steel bowl, spiral dough hook and bowl ... High torque direct gear drive transmission; Oil bath transmission.
    Globe SP62P Gear Driven 60 qt. Commercial Planetary ...
    www.webstaurantstore.com > ... > Commercial Floor Mixers
    Commercial Planetary Floor Pizza Mixer - 3 HP. In stock ... What is White Glove service? ... Globe XXBOWL-62 60 Qt. Stainless Steel Mixing Bowl for SP62P Mixer.... Planetary grease fitting and gear oil meter. .... Globe SP62 and SP80PL MixerControls .... 2003-2016 WebstaurantStore Food Service Equipment and Supply .
Jan 30, 2016 | Globe Food Mixers
When itry to make bread dough in the mixer, the bowl locking mechanism doesnt work properly and the bowl moves and top of mixer jumps around how can i fix this
You need to make sure that the hinge pin is tight, turn machine completely upside down and tighten the slotted screw up inside the pedestal. If that doesn't fix it you will need to check that the locking lever is properly engaging in the slot. You may need to "SLIGHTLY" file the slot in the pedestal that the lever engages into. If you go mad with the file you could wreck the slot.
Sep 13, 2014 | KitchenAid Kitchen Aid KSM150PSMY -...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
My KitchenAid bowl keeps coming loose when kneading dough. Any solutions?
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending Shed.com
Apr 16, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
How can i tell the which size my mixer is?
A 200 means 20 quart. I assume you have no bowl or else you can just measure the volume of the bowl.
Nov 29, 2009 | Hobart A200 Stand Mixer
Motor stalls out when mixing you unplug and plug back in and it will run had the motor checked out and was fine
You are overloading the bowl or you bought this used and when they wore the motor out, you ended up with it. Batters & icings 75% bowl capacity, doughs 65% bowl capacity. If you live by this, you will buy 1 mixer & never have to replace it, especially if it's a Hobart.
May 01, 2009 | Food Mixers
New bowl & hook hobart d300
There is a website called onesharpstore.com, It carries parts for the hobart 30 quart mixer. I specifically saw the bowl and hook attachments as well as others like beaters and a cheese and vegetable grater. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
Feb 25, 2009 | Hobart D300 Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Bread hook use
Use it to the side. This will pull the dry ingredients off the bowl. If the dough is coming out lumpy, make sure you follow the recipe exactly. Putting dry into wet will give different results than putting wet into dry. If this doesn't end the lumps, try a different type of flour.
Oct 15, 2008 | Sunbeam Heritage 2346 Stand Mixer
Food Mixers Logo
110 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
