Question about DeLonghi A120E Air Conditioner
Leaks when it is running on ac
I cleaned the filter but it still leaks
    Guru:
  • 1,524 Answers
Clean the drain pan.
Posted on Jun 02, 2010
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
Oily and dusty smell comes out from the AC.
Change your cabin filter! Also check for any leaks at engine burning off on exhaust. When you close your hood there is a rubber seal ( glass side) , make sure that is in place. If engine is dirty try power washing it. A clean engine is easier to pinpoint leaks
Nov 20, 2013 | 2010 Toyota Yaris
High low side pressures and sight glass contains lots of bubbles
The system has a lot of air in it. If u haven't had any AC wk done on it that mean there is a leak in the system. System must be evacuated, pressurized & find the leak. Repair the leak, vacuum air from system & charge w proper AC gas. SPECIALIZED EQUIPTMENT & GAUGES NEEDED. good luck
Jul 28, 2017 | Cars & Trucks
I have ac unit which is only a year old. I just recently installed it, the fan is working but the ac is not cooling when set on cool. I cleaned the filter already, not sure what else i can do to fix this...
if you can here the compressor kick on (the fan will also be running) if the compressor is running and not cooling you could have a leak and it needs fixed and recharged
May 31, 2011 | Kenmore Heating & Cooling
I have a Amcoraire that leak water during running AC
blow in to the drain from outside also check and make sure the filters are clean
Jun 07, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Not cooling properly. dismounting the front panel showed formation of ice on ac tubes
ice forming on the evaporator coil (you called it ac tubes) is a common sign of 'low' air flow across the coil.
The evaporator coil will 'ice' if the air flow is restricted.
This usually happens when the filter and or coil becomes dirty.
If the filter is changed often (when dirty) then the chances of the coil becoming dirty are reduced.
In any event - you must have a 'clean' filter and a clean coil.
The filter is usually made to be 'washed out,' and the coil can be cleaned with a wrag - or brush of some sort.
The goal is to make sure the filter and coil are both clean.
Other things can cause a coil to 'ice,' but are less likely.
a) low on refrigerant - not likely because the system is 'sealed' and the chances of losing gas are remote unless it's an older AC and has been 'opened' in the past - which improves the chances of a leak.
b) a problem with the fan motor - i.e. cutting off and then back on - or - not running as fast (both will reduce the air flow) as it should because of internal problems.
c) in a room with a 'low' load - i.e. the outside temp is low and the room is cool - thus causing a low load situation. This too is not likely as most AC's are being run because it's hot in the room.
Bottom line - is I would make sure my filter and evaporator coil are both clean and unrestricted.
good luck!
May 09, 2010 | LG BG8000ER Air Conditioner
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
I have an amana ac unit that is leaking water out of a hole that is right beside the drain pipe. i cleaned the drain pan out and made sure the drain pipe was cleared out.water starts coming out when the ac...
check filter or coil plugged if drain is clean or there is no vent so the fan holds the water while running then when fan shuts off it lets it go
Jun 21, 2009 | Heating & Cooling
Water leak on passenger side on 99 chevy s 10 not anterfreeze, leaks when not being driven
there is only one thing that leaks water there, that is the AC condensation drain, water forms as part of the AC cooling the evaporator core, this water must be drained away or it will flood onto passenger area, so there is a drain on the passenger side at bottom of firewall, will leak allot of water depending on how humid the air is.
May 05, 2009 | 1999 Chevrolet S-10 Pickup
DeLonghi A120E Air Conditioner Logo
268 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
