Question about Element Electronics FLX3210 32 in. LCD TV
I had the same problem as other people. TV wouldn?t turn on but it was getting power. I have the second run with a separate inverter. I replaced the main board from shopjimmy.com and that cured the problem but now the picture shows like a negative. The colors are mixed up and the channel buttons do not work correctly.
  • Rich Martin Jun 05, 2010
    How do I remove the T-Con board? Can I access it from the back?
  • Element Elec... Master
  • 8,457 Answers
This problems the T-Con board have problems not working correctly,this board sit at the bottom at the center of the of the LCD screen panel.Replaced it.
Posted on Jun 02, 2010
  • Jeramie
    Jeramie Jan 21, 2011
    depending on what board you changed, you may need to adjust your voltage to get your clear picture back. Each board is adjusted exactly to the tv it was fitted for. You will need some technical skills here.
What is causing my LCD tv to turn off on my Toshiba 52hl167 tv.
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 13, 2016 | Toshiba Televison & Video
Tv turns on and screen flickers on for a second and then turns off, whats the issue?
Sounds like Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
Jul 28, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
I have a Polaroid 40gsr3000 40 in lcd tv. sound works no picture. think maybe inverter board. One board in middle of back .one long strip board that runs along bottom of tv. Is this inverter board?
What you have is an led tv . And the inverter for the back light led is there in the main board (mother board.) of the tv. Its no a separate board.
The the Log board you see is the TCON board which drives the led panel.
If you wish replace the inverter the you have to bay new mother board for you tv. In the model you have Almost every thing is integrated to the mother board like power supply ,back light inverter board the cpu section.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 30, 2015 | Polaroid Televison & Video
How to fix LG 47LN5200 TV?
Nov 30, 2015 | LG Televison & Video
I have a Samsung ln s3241d 32" lcd the backlight goes out after tv is on for about 1 second. If i shine a flashlight into the screen I can see the picture. I noticed the power supply making a slight high...
I have a 46" Samsung LNT4665 with the same problem. Originally had the power supply replaced but 1 day later I have this problem. Auth. repair shop says it's likely inverter, but apparently can't be replaced separately, must be replaced with panel ($700 , and labour on top) might as well buy a new TV.
Any suggestions? I have seen the inverter sold separetly on some websites, anybody try replacing that part?
Oct 13, 2010 | Samsung Televison & Video
The TV turns on, has picture, then after about 15 seconds goes black but still has sound
The two most probable failures is the backlight for the display or the inverter that powers it, If the ends of the fluorescent backlight tube are exposed, check if the ends are black. If not, then the inverter is probably bad.
These are mounted on separate smaller boards that are pretty obviously connected to the backlight tubes.
Aug 17, 2010 | Westinghouse Electric SK-32H570D 32 in....
I have a Element 32" HDS LCD TV, movel ELEFLX3210. It won't tunr on, but has a red light that is on. The TV was purchased 09/09/2007. Do you know how to repair or address this? It's a $549 TV.
There were two runs of parts on this model, one using a powersupply board that included the inverter and one with a separate inverter. The red standby light failure was typical with the second run with the all in one power supply board. You can tell if you have the second run by opening the back. If the power supply board says proview and is black then you need to replace the board underneath it. The main board. This model also had a MASSIVE factory defect. If you hook up the VGA model, pin nine on the control box lead shorts out and it goes into limbo like you have now. So, replace your mainboard and Fill the vga input with hotglue. That should get you back and kicking again. Try shopjimmy.com or ebay for parts.
Good luck
Aug 01, 2009 | Element Electronics FLX3210 32 in. LCD TV
Phillip tv
Probably bad inverter board. It has a short in inverter board and as soon as it powers up it detects the excessive current draw and shuts the set back off. Open it up, unplug the power supply connections to the inverter board then try to turn it on, if you get a green light then the inverter is bad. Try E-bay for replacement board.
Apr 16, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Element Electronics FLX3210 32 in. LCD TV Logo
258 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
