Philips LCD 51PP9100D/37 Has no display and continuously recycles on & off.
  • dmjenkins504 Jun 03, 2010
    After I explained to my daughter I no longer have the tools to do this kind of work-- she decided to have a technician fix it for them.
    Thanks for your suggestions, and I will keep you in the loop until it is fixed.
    Don
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with open the back of the unit and then check the power supply board for any bad (bulged/swollen) capacitors. Power supply board is the board where all the power cords/plugs goes into. The inverter is the power supply source for the backlights. If that’s the issue then it’s always better to replace the inverter board completely just to avoid any future issues. After you have checked that also check the main board and if you can use a multimeter to test the components on these boards. All this should only be done if you have knowledge of internal circuitry of the unit as the components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
  • dmjenkins504 Jun 02, 2010
    Hi Rylee,
    I will not be able to check the power supply board and the inverter. Do have an estimate how much these parts will cost if I install them myself.
    dmjenkins5049@msn.com
  • Rylee Smith
    Rylee Smith Jun 02, 2010
    Thanks for your reply. You'll need to check or get it checked that which part out of these two has gone bad, although it seems to be the power supply. The cost to get this repair from a professional will be around $250-$300 including labor depending on the parts that have gone bad. If you DIY then it'll be around $150-$250 depending on the parts that have gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
My philips lcd model 47pfl7432d/37 has a fuss nd that fuss is all white is dat how it come or is it no gud?
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 08, 2016 | Philips Televison & Video
PHILIPS 51pp9100d/37, picture is warped ? where do I get the parts i need to fix it ?
If it looks like attached photos it needs both of the convergence IC chips replaced. They should be stk=392=120 OR a few models used the -110 chip.
below is what the parts look like
Jun 15, 2012 | Philips 51PP9100D 51 in. Television
My 51pp9100d/37 philips TV doesn't have any sound.
This set has a "small signal board" The board is about 3x5 inches and plugs into board on far left as seen from back of set.
A lot of these fail:
low sound
no sound
intermittant sound
no remote functions
no channel up or down
etc etc
Last time I looked board was around 100 exchange rebuilt
Mar 13, 2012 | Philips Televison & Video
I have an 51pp9100d/37 Phillips Tv, and i the red and green colors on the picture are skewed to a weird, almost sideways, S shape. I was wondering if this is an easy fix and cheap, i don't really know...
From what you have said it seems that you need to replace the Convergence ICs, they are Big Black ICs and will have Part number on them ,example STK392-110
Mats Electronics has Parts $9.95 each IC. 1-800-628-1118
PTS rebuilts boards 1-800-844-7871
Jun 29, 2011 | Philips 51PP9100D 51 in. Television
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
I need the service mode sequence for my philips 51pp9100d/37 so I can manually change the resolution on my tv. The resolution somehow was changed and when I HDMI my laptop to the tv it wont display t
I suspect that you may be using a cable or sat box rather than that set's internal atsc tuner.
Sometimes these boxes are not set up properly or reset themselves to a lower resolution.
Go into your box's settings menu nd look for the resolution settings. Verify that all of the modes or at least the maximum resolution for your set is enabled.
May 02, 2009 | Televison & Video
Philips 51PP9100D/37
try unpluging the set again for 5 minutes, if no help go into the menue and make sure that tha speakers are turned on. also try turning up the volume
Oct 19, 2007 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
