Question about Microsoft Xbox 360 Console
E 72 error xbox 360 - Microsoft Xbox 360 Console
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
Click Here to download the repair guide
dont waste money by going to repair shop........... with out knowing much you can repair your XBOX360 with the help of this guide .........
Posted on Sep 04, 2010
    Scholar:
  • 121 Answers
Contact Microsoft. This problem is seemingly linked to the 3rlod and is therefore covered at 2 extra years of coverage for free.
Posted on Jun 03, 2010
2 Suggested Answers
  • 150 Answers
SOURCE: What is error 72 on the xbox 360?
This is a dashboard error, namely your Xam.Xex is bad.
Posted on Dec 31, 2009
Want Xbox 360 Support to fix 'Open Tray Error'
In order to fix this error, first make sure that error lies within the XBOX 360 but not with the disc only. You can check this by inserting different disc into the XBOX 360 console. Xbox 360 support can handle almost all types of Xbox consoles. Microsoft Xbox Support can solve your problem in minutes.
Feb 27, 2017 | Video Game Consoles & Games
Error 40a3-0000-3080-0502-8007-045d
I got this from the Xbox support site for your error code.
Error Code xxxx-xxxx-xxxx-xxxx-8007-045D
A storage device (such as a memory unit or hard drive) was not found during the software update. Follow these steps:
  1. Turn off your console.
  2. Remove all console storage devices, including any USB flash drives, external hard drives or the internal hard drive on the Xbox 360 E console or Xbox 360 S console. Learn how to remove the hard drive.
  3. Add your primary storage device, for example, the hard drive.
  4. Turn on the console
  5. Try updating the console again.
Here's the website if you wish to peruse it further.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Post back how it works out!
Jan 06, 2014 | Microsoft Xbox 360 Console
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
Dec 31, 2009 | Microsoft Xbox 360 Console
Red light problem, freezing up
if it's still under warranty and not chipped then yes microsoft should replace it. if not you can fix it yourself by buying an x clamp kit, it's quite easy to repair. the best is here http://cgi.ebay.co.uk/XBOX-360-X-Clamp-Fix-Kit-RROD-Xclamp-Repair-HQ-Paste_W0QQitemZ330337699118QQcmdZViewItemQQptZUK_VideoGames_VideoGameAccessories_VideoGameAccessories_JN?hash=item4ce9a9452e&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1687|240%3A1308|301%3A1|293%3A1|294%3A50
Jun 18, 2009 | Microsoft Xbox 360 Console
Error code from my xbox 360
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Jan 18, 2009 | Microsoft Xbox 360 Console
System error
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.......
try a alternate harddrive or boot it up with only mem unit
Dec 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
441 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
