Question about Creative Labs Inspire T3000 Computer Speakers
My speakers won't make a sound.
Everything seems to be plugged into the right place, but no sound whatsoever comes out... The sound control device that came with the speakers is lit up and I can hear the speakers buzz when I get a text message or something, but I can't play anything on my computer without inevitably sitting in silence and frustration...
Is there a power button I'm missing? Please tell me this problem is easy to fix. hahaha
Process of elimination... check your cable hookup first. then control panel and check sound, right click on properties tab and do a diagnostic.
Posted on Jun 02, 2010
I have a set of Bose computer speakers and they seem to have just stopped working, everything on my computer says they are working fine and when I plug them into my laptop they work, so what could be the...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 24, 2011 | HP Audio Players & Recorders
Went on vacation, came home and now speakers won't work. subwoofer blue light is on and everything is connected right. what could be the problem?
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | Harman Kardon SoundSticks Computer...
P5GD2 Deluxe motherboard in my PC. Recently I installed windows 7 (32bit) and everything seems to work fine except that there is warning that no audio device is connected
also
hope this helps
May 24, 2011 | ASUS P5GD2 Deluxe Motherboard
I have a set of Logitech speakers s150 USB and Ive had them for about over a year and about a few days ago they were working fine...but now they just won turn on. usually i just unplug them and replug them...
also
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
also try this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or
hope this helps
May 17, 2011 | Logitech S150 2 Speakers
I'm having problems with my Creative Labs Gigaworks S700 speakers. Last night they were working fine, and this morning there is no sound whatsoever. I have them plugged into my laptop, and the laptop...
also
hope this helps
May 16, 2011 | Audio Players & Recorders
Occasionally i cant get any sound to come out of the speakers, i unplug everything and still not working.what is the problem?
if you are having problems with your sound
also
hope this helps
Apr 12, 2011 | Bose Companion II Computer Speakers
I have just bought some Logitech surround sound speakers (Z506) and the rear two speakers don't seem to work. I have double checked all the cords are in the correct place and that they are securely in....
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 05, 2011 | Computers & Internet
My sound card, windows everything ok, but sometimes sound doesn't come through the speaker. it gets power and everything.......even the blue light of the controller is ok......wat shud I do???? sometimes...
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 26, 2011 | Altec Lansing MX5021 Computer Speakers
Sound only works with headset. No longer comes
If the sound is working through another device then it seems that the internal speakers are bad. Because if the sound card was bad you wouldn't have any sound whatsoever, same goes for drivers. Probably just some bad speakers. If you have some other external speakers try plugging them into the headphone port and see if that helps.
Mar 08, 2009 | HP Pavilion dv6000z Notebook
Sound loss to PC computer speakers after a Systems Recovery.
First, check that the speaker icon in your system tray, (lower right hand corner) is not muted by right clicking on it and selecting volume control. If not muted, goto My Computer, right click and select Properties, Click the hardware tab then device manager, left click on the + next too Sound, right click on the device that appears and select uninstall, once it is uninstalled, restart your PC. Let me know if that works.
John
Nov 25, 2008 | Logitech Z-560 Computer Speakers
Creative Labs Inspire T3000 Computer Speakers Logo
235 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
