Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Rotator arm is detached from gear - Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
  • luisa_sgro Jun 02, 2010
    sorry to ask you this but could you be more specific on the part that is faulty.where is this part located in the machine? did you mean the roto motor,or the wash arm? please reply 4 further help
  • Fisher and P... Master
  • 3,247 Answers
I am assuming the plastic wheel type device which moves the washer arm has come out.
I think you will have to buy the whole rotor assembly. Should cost around $50.
Go to page 17 of Parts Manual and check part no. 5 Rotor assembly.
I have seen it is available from Fisher and Paykel parts shop online. They are located in Milwaukee (ie, if you are in USA)>
Posted on Jun 05, 2010
  • Sam Jun 07, 2010
    As mentioned in my last posting, it is the rotor motor assembly located at the base of the drawer.
    Not sure if you have seen the parts manual for which I sent you web link.
    Please post a comment to confirm if you are able to find it or not. From your description I gather it is the plastic wheel attached to the rotor that has broken. The washer arm is only a metal part.
2012 chevy cruze mode door actuator
Yes, it's most likely the mode door actuator. Lots of YouTube videos that show you how to replace it.
Nov 30, 2016 | Chevrolet Cruze Cars & Trucks
Machine is Quivering while excersisng
follow this steps and fix it. God bless you
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
Nov 13, 2013 | Sole Fitness Sole E55 Elliptical
Quivering while excersising
C846 hard to pedal
follow this instruction. God bless you
Jul 21, 2013 | Precor C846i Experience Series Commercial...
Machine squeaks
see the next steps and fix it. God bless you
Nov 19, 2012 | Schwinn 420 Elliptical Trainer
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Front sprocket
put a 2x4 or similar through the back wheel on top of swing-arm: this will lock wheel from rotating while you crack the nut.
NEVER put the transmission in gear.
When re-torquing the nut after refitting, put the 2 x 4 under the swing-arm instead of on top (since wheel will want to rotate opposite direction
Feb 21, 2009 | 2000 Suzuki TL 1000 R
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
85 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
