Question about Panasonic KX-TG5621 Phone
It says line in use and I am unable to dial out. I do have a tone but not a regular dial tone. It has a brand new battery fully charged but that didn't fix the problem.
  • 532 Answers
Go to call setting to unbarred outgoing calls and the incoming calls.
Posted on Jun 03, 2010
Why no dial tone??
have you plugged your new phones telephone line into the telephone socket?
Aug 01, 2014 | BT 4500 Cordless Phone - DECT - Satin...
How do I get a dial tone?
Is the base station plugged into the phone jack on the wall?
May 17, 2014 | Swissvoice Epure Full Eco Cordless...
No dial tone on a cordless phone
Some units if the battery is not fully charged or any ac adaptor for another phone also connected is not plugged in you will now have no dial tone.
Dec 15, 2012 | GE Lands Phones
I just got a uniden cordless phone and it has no dial tone
Allow it to charge for at least 2 hours. If after 2 hours you have no dial tone Unplug your Phone and plug in a regular un-powered phone. If you get DT your phone is out of box defective, and you will need a new one. If it does not have dial tone then there is a problem on your phone line and you need to contact your phone company. Note, the phone company will charge you for repairs inside your house.
May 05, 2011 | Uniden DECT15602 Cordless Phone
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Jul 07, 2010 | GE T28821FE2 19 GHz Twin 1Line Cordless...
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
I cannot call out on my KX-TG9331T. Coming in calls ring busy
Try switching batteries with one of your other handsets known to be in good working order or replace the batteries in the handset with the problem with new ones
Apr 20, 2017 | Panasonic KX-TG1033S Cordless Phone
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
Phone has not dial tone or buttons have no function
This is not a problem..You will need keep your phone plugged into the power jack and the powe switch must be on.Then connect the phone line..thats all the phone will register itself and start working..
Oct 19, 2007 | Lands Phones
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
Panasonic KX-TG5621 Phone Logo
313 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
