Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
Belt will not tighten when tines are engaged
I get the tiller going, while plowing the tiller is weak. When I release the engaging bar, it will not retract. The cable stays loose, and the tiller keeps on going, but still weak. Theres no spring on the lever of the cable. Should there be? Please help before weeds take over my garden!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
There should be a spring on the other end of the engagement cable connected to the take up (idler) pulley. It sounds like it have broken or came off. You will need to removed the side cover and inspect. After you have the cover off, pull the engaging bar and watch the take up pulley for correct operation.
Posted on Jul 01, 2010
I have a f22o honda rotor tiller.it runs great but when i put the unit in dirt it won't spin.it will if it's not touching anything.
You probably have a belt drive that has is not tight enough to pull under a load. The belt is pulled by an idler pulley that engages when you start the tines. Check the belts by working you engage lever and look for the belt and idler. More than likely there is an adjustment that will allow you to put more tension on the belt thus making it till. Do not do this when the machine is running! The belt should not have flex in it when engaged. It may a little effort to engage the tines when you get it tight enough to till.
Col. Dana Gillespie
May 04, 2015 | Honda Tiller - F220
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
My white tiller won't engage but grinds a little any ideas?
make sure the linkage is adjusted right
Apr 06, 2012 | Mtd Garden
I need to find out what size belt for tine engagement on a Dayton 5hp Tiller model # 32885 C144B
a simple way to figure out the length is to engage the tine mechanism and take a string and wrap it around the pulleys mark it and take it to any belt store, and buy the Belt you need. You will need to know if it's a 3/8s or 1/2 inch drive belt. Normally tine belts are half inch or 5/8 wide on a 5 horse power motor, You can get these belts at sears or Nappa auto parts store. hope this helps.
Mar 19, 2010 | Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Craftsman 6.5 tiller model 486.252444
Not sure about this tiller but some others just need oil in the crankcase - tillers tend to lose oil because of the harsh conditions they work under. If you hear squeaking down their it might be a good idea to check it out.
Apr 19, 2009 | Craftsman Cultivating Shield
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
165 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
