Question about Sony XM-1502SX Car Audio Amplifier
Over current is lit? - Sony XM-1502SX Car Audio Amplifier
  • Shahid Electronics
    Shahid Electronics Jun 03, 2010
    That means over current light is lit on amp. Now answer it, why it lit?
    Sergeant:
  • 293 Answers
Hi and thank you for using fixya:
Please clarify your problem and restate your question. I did not understand over current is lit? Please let me know
Thanks
Posted on Jun 02, 2010
What pilot light assy. do I need to buy for model# 640y0rt4, water heater ??? please wont stay lit
check that the flame sensor is clean. It would be a stiff piece of wire that would sit right over where the pilot lite is. If it is dirty...it wont sense if there is a flame....and if it dosnt sense a flame....it wont let the pilot lite to turn on.
Jun 03, 2015 | Reliance 606 Series 40 Gallon Natural Gas...
Have a Harris Vent Free Propane Gas Log, 65% gas left, the pilot will not stay lit.....any help?
check the pilot generator for proper current. check from PP terminal to TH/PP terminal while pilot is still lit. you should be getting well over 250dc millivolts. if not, replace the pilot generator
Dec 14, 2014 | Heating & Cooling
ODS will not stay lit
The pilot generator (aka thermocouple) has gone out. This is the little peg that is mounted close to the front of the burner. The flame heats the thermocouple and it puts out a millivolt current that holds the gas valve open after you release the button. The TC is no longer putting out enough current to hold the valve open.
I beleive the part # is TT15c-11, (about $15)
Dec 14, 2013 | Dyna Glo 18,000 - 30,000-BTU Liquid...
Gas burner wont stay lit
Is it the Pilot, or the main burner that won't stay lit?
The pilot has a little 'flame rod' in the path of the pilot flame, that conducts a tiny current thru the flame, to a detection circuit-- assuring that there is a pilot flame-- If that rod get's dirty, it can cause false trips. Is that any help?- Mack B
Oct 25, 2013 | Honeywell Pilot Burner for Natural Gas,...
My amp just stopped working one day almost new dont known why
DID YOU CHECK YOUR FUSES? Is there anything lighting up on it to see if it is in fact turning on? If it's lighting up and there is no protection lights lit up then check your speakers to make sure you didn't burn them up. If there is a protect LED lit then unhook your speakers and see if it stays lit or not. If it stays lit then check to make sure you're getting enough voltage at the amp connection, minimum of 11.0 volts is required just to get it to turn on. If it has under voltage and over voltage protection LEDs see if they're lit. If you do all of these things and are getting enogh voltage, your speakers are not burnt, your protection LEDs are lit no matter what then you need warranty repair that amp. If your speaker wires are shorted it will make your amp shut down also, but since you were using it for a day or so my bet is that you burnt up one of your speaker voice coils and it's internally shorted and that will cause your amp to shut down in protect mode. Otherwise you probably internally fried your amp by too low of voltage or not enough current (amperage) due to not large enough conductor (too small gauge wire) should be minimum of 8 Ga. for each amp, 2 amps will require 4 Ga, 3 or more will need 2 Ga, or 0 Ga. wiring to keep the voltage and current flow high enough to keep from damaging the amps. Good Luck!
Aug 20, 2013 | Phoenix Gold RSd1200.1 Car Amp
Clock display stays lit
yes on some cars this is normal, the amount of current that the clock draws is very minimal and should not cause problems with a battery. Unless not used for very long periods
Jul 09, 2012 | 1995 Buick Skylark
The heater is attached to the propane tank properly; however, when I try to light the heater, the push valve does not allow the gas to pass to the heater to be lit. I do have all of the valves open on the...
Typically there is a safety device directly above the pilot light that must be up to temp for the gas to flow. You did not specify if the pilot is lit. If not, hold the lighter at the pilot light while depressing the button for one minute. This allows the sensor to warm to operating temp, thus allowing gas flow. Once pilot is lit adjust the temperature accordingly.
Feb 19, 2011 | Heating & Cooling
I have green light so I know the bulbe is good,
just because the green light is on doesn't mean the bulb is lit. look into the lens from the side--not directly into it to see if it is in fact lit. if it is lit but you have no display, the main board is likely bad, but you can try resetting the lamp hours and reflashing the unit with the most current firmware.
Jun 17, 2010 | InFocus X2 Projector
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on
by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press
ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each
program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended
and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end
shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
The orange engine symbol on the dashboard of the hyundai coupe 2001 model remains lit when the engine is started and then starts to flash.
this is your check engine light it is lit because the computer has detected a fault and a trouble code has been stored. it starts flashing because this is current and damage to vehicle can result. need to have the codes pulled
Oct 06, 2008 | Hyundai Tiburon Cars & Trucks
Sony XM-1502SX Car Audio Amplifier Logo
77 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
