Question about Altec Lansing ADA745 4 Speakers
Very low volume coming from speakers
I have to turn both the volume on my computer to "100" and the actual volume on the Altec Lansing speakers up almost all the way to the highest setting on the dial located on the right front speaker to hear adequate volume lately on my computer. These Altec Lansing ADA745 4 Speakers used to CRANK and be very loud if I turned them up. Now, I can't seem to get enough volume out of them. I've tried disconnecting the green audio cable and subwoofer cable, and reconnecting but it has not helped the problem. The cords are in great condition and plugged in securely to the subwoofer as well. Once in a while, the sound will suddenly get very loud for a second or so, or I'll hear a bass/subwoofer noise then it will go back down. Do I need new speakers or is there any other troubleshooting you can offer me? Could it be a new fuse needed in the subwoofer? I get some volume, just not enough or close to what I once did. Thanks!
I find out that beck of subwoffer right front wher you controll volum that conection to subwoffer is bed than it wont work i try evrything and this what i find out i have two pair of saim ada745 as soon as i chane from outhr computer its working fine so PROBLM IS NOT DRIVER SOUND CARD BUT SPEAKER CONNECTION.....................
Posted on Apr 25, 2011
  • 27,725 Answers
You might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
or
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no4 for australia
hope this helps
hope this helps
Posted on Nov 02, 2010
I have exact same problem i think its got something to do with volume controller on front right speaker damn shame as the sound was awesome
Posted on Jun 30, 2010
5 Suggested Answers
SOURCE: Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
Posted on Jun 22, 2008
  • 77 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
  • 101 Answers
SOURCE: Where can I download a driver for Altec Lansing
HI, maybe theres been a bit of confusion but your Altec Lansing ADA745 speakers shouldn't need any drivers.
Its kind of similar to you plugging in a pair of headphones into your cumputer, they should work just fine.
Are you not getting any sound? Post the details of your PC (is it a dell?)
model number etc... and describe your problem
You probably need audio drivers for your audio device(inside your pc on your motherboard),
Posted on Aug 04, 2009
CreativeTECH
  • 1719 Answers
SOURCE: Can I connect my Altec Lansing ADA745 4.1 speaker
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Posted on Apr 09, 2011
Altec lansing acs45.1 cannot increase volume level by using arrow buttoms on top of cube speaker...sound does come out but a very low levels......have pret
This is a loose connection between PC and the Sub-woofer. The cables may damaged or it may be a hard ware problem.
Think this is helpful !
Aug 11, 2010 | Altec Lansing ACS 45.1 Computer Speakers
Low volume on Altec Lansing 4.1 system
if the volume controls of the speaker is set to 100% together with the volume control on your computer then still get a low volume,try some other device where you can use your speaker like mp4,if still got same problem,bring it to a service center there might have a problem with the amplifier.
Sep 10, 2009 | Altec Lansing Multimedia Computer Speakers
Speakers have are hooked up won't work???
goto adjust audio properites and u can sort out all the volume controls there
Feb 24, 2009 | Altec Lansing ADA 305 Computer Speakers
Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Jun 24, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec lansing speakers series 100 plugged in but sounds are distorted
I have to turn the volume to max to hear any sound. Up until now the speakers were great and only needed to be turned on slightly? any suggestions please?
May 07, 2008 | Altec Lansing Multimedia Computer Speakers
Altec lansing ada 745
need to check your control center,then if thats not the one"it should be set @ 3/4 volume....
if no diff,,,,,then you need to go over checking every program that shares it,,,has their own volume control,,,somewhere there is the problem,,,maybe real player,,,media player,,,flash player etc...
thnks ttyl
Polywoggy1@hotmail.com..
Mar 10, 2008 | Altec Lansing Multimedia Computer Speakers
Altec Lansing 4.1 ADA880
if you are a technically skilled person
simply clean all the IC(chip) leads, by using a blower or using a painting small brush
the dust come in contact with the other pins that make this problem
Jan 23, 2008 | Altec Lansing ADA 885 Computer Speakers
Speakers cutting out at higher volume
Check the power /voltage printed at back side of speaker ,test w/ volt meter /if supply not enough current to drive the amplifier.The sound are very low and humming.
Jan 02, 2008 | Audio Players & Recorders
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
Altec Lansing ADA745 4 Speakers Logo
883 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
