Question about Nikon Coolpix 3500 Digital Camera
Bad picture clarity
The pictures went downloaded into the computer has got defects in the form of horizontal lines. It compl;etely spoils the picture .
Could you please advise on how to go about this prblem , if there is any service centre in mumbai it would reallly very helpful if u let us know about it . Please contact us on [email protected] .
Thanks for your precious time.
Regards
JOHN
  • 4 Answers
If the lines don't show up on the camera, it may be a cable problem, or connection problem. It also could be a USB 1 to 2 problem, where it is a USB 1 port, with the camera using USB 2, and it is not supported, because the USB2 is faster.
Posted on Apr 09, 2008
SOURCE:
Has sound but no picture horizontal line defect.anbonn brand
Horizontal lines generally mean the panel is bad and the set needs to be replaced
Apr 02, 2018 | Televison & Video
What is the problem of my camera when you review the picture there is a horizontal line forming in the lcd screen,
I'm afraid when the line is visible on the computer to, when you view the pictures, your camera sensor is defect. Probably not wort the money to repair that. When the pictures, viewed on the computer look ok, the display of your camera is defect. Try to live with that one. A new camera could be cheaper than cost for a repair.
Mar 15, 2015 | Cameras
Retrace horizontal line
It seems to be some line frequency interference is effecting the picture.
Jun 07, 2013 | Televison & Video
At first it was lots of horizontal lines over the screen, and later TV screen went completely black. The sound still is perfect. Perhaps I just need to replace the fuse? I love this TV! Thanks...
Hello
You have stated that your TV has a lot of horizontal lines before it went off picture. We say that lines as retrace lines. So many of them will there on the entire screen, at about one inch or so apart, horizontaly scattered along with picuture. At that time, you may be unable to down the brightness control also. Even though you have reduced the brightness control to zero position, there will be some brightness level on the screen. You should have to repair that fault at the begining. There is a voltage going to the picture tube base, known as screen voltage. That voltage determine the emission of the picture tube, and we call it a bias voltage. When it goes higher than normal, this trouble ie retrace lines will occur. In long run it may spoil the picture tube itself. I don't know what the case of yours.
Anyway it is best for you to consult an experience technician in this case. Ok.
Nov 05, 2010 | Sony KV-35V35 TV
Kodak 2gb memory card picture shows on camera but not computer
The Memory card is defective if u continue to use the same memory card more pictures which u take may spoil so pls try to use a diffrent memory card it will work fine.........
Dec 15, 2008 | Kodak EasyShare C315 Digital Camera
Toshiba 42 WH36 P REAR PROJECTION
You have a convergence problem. Need to replace convergence IC's.
Jun 02, 2008 | Toshiba 42H81 42" Rear Projection...
Dell 1704fpt Screen turns white
ok,your monitor has a defective vertical ic.when vertical ic is defective you can see the horizontal line.
Oct 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Tv does not turn on
You does not mean about picture clarity before this problem occurs. Former the picture clarity is well and good means picture is not problem. There is a problem in horizontal deflection area.May be flyback transformer failure shows these type of problem. This service should be done by technical persons only.
Aug 27, 2007 | Sony KV-32S42 32" TV
Nikon Coolpix 3500 Digital Camera Logo
52 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
