Question about Dryers
MAYTAG LSE1000 DRYER
I have a Maytag LSE1000 Series 01 stackable dryer that humms briefly when I turn it on, then gives me the following error code: E2.(it won't spin at all). I can't find a manual for this model; does anyone know what this error code means?
  • Anonymous Jun 02, 2008
    same problem
5 Suggested Answers
SOURCE: my maytag dryer
We bought this machine last year, converted it to propane & have loved it. All of a sudden there is no ignition ( fire). I have taken off the front & cleaned everthing I could see. Still no fire. I have check the gas supply, the drum is spinning, the only thing I think I heard last year right after it started and right before the "FIRE" was a clicking sound? What ever you might sugest would be greatly appriecated! Thank You, Don Wagner Jr @ SmoothSeal1@aol.com
Posted on Jan 17, 2008
  • 52 Answers
SOURCE: I have a maytag stackable which the dryer drum no
You may just need a part. belt, idler pully etc. It may be an easy fix check it out.
Posted on Nov 07, 2009
Daniel S
  • 4323 Answers
SOURCE: My Maytag Dryer -- LSE1000
Hi
Error 9E on Maytag dryer means "Door Switch failure". This error appears when the door switch has gone faulty or the connection to the door switch is loose. Please check the connections to the door switch, if the wiring looks fine then you'll need to check door switch using a multimeter. Replace the door switch if no continuity is present when machine is turned on and door is closed. If the door switch seems to be fine with a multimeter then check the wiring to the control board using a multimeter. Hope this helps... Please post back for more information.
Daniel
Posted on Nov 28, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Re Maytag dryer model
Sorry to read about your problem, I hope this helps you out.
all most all of it
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 28, 2010
Testimonial: "Thanks for assistance - very quick! Was wondering if it was going to be time consuming to repair the dryer and I guess it is. Murray"
Maytag Bravos Dryer quiet series f01 code
F-01 Means the main electronic control board is likely to have failed.
Unplug the dryer for 5 minutes and the plug the dryer back in. If the code reappears, replace the main electronic control board.
This is where I would start.
Maytag Dryer Circuit Board Timer Parts
Dec 19, 2017 | Maytag Dryers
Maytag dryer 3000 series MEDE300VW1 7 years old dryer will not start F01 code comes up many people say replace the electronic control board,how do I troubleshoot on which one is bad?
code f-01 refers to condition main electronic control board failure
you fix if you want to diy is to buy another board from the service agent spares and replace the existing board
however while that error code is coming up, you would ba advised to get in a technician to check out the machine to see if there is not another problem causing he board failure
Jan 09, 2017 | Maytag Washing Machines
I need color coded wiring diagram for maytag combo model # lse8500ace
Double Check Model Number. Can't find anything with that model. Have LSE1000 and LSE7806 which are stacked Washer and Dryer
Nov 18, 2015 | Maytag Dryers
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
Maytag stackable dryer
STACKABLES ARE NOT KNOWN TO HANDLE TO HANDLE HEAVY LOADS.TRY PUTTING LESS IN THE DRYER.
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer wont heat
First answer is yes; high resistance is good. I am not sure I understand the second question. The reasion one has to isolate the element is to avoid resistance from other parts. This, I believe , is the most likly problem.
Dec 26, 2008 | Maytag SDE2606 Electric Dryer
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Dryers Logo
583 people viewed this question
Top Dryers Experts
