Question about Cfm Klimaire KSWG009H113 Split System Air Conditioner
After installing my klimaire mini split unit yesterday I heard the freon go through the unit and it worked great.Today when I turned the unit on the fan would work but the unit would not cool it also flashes a 7 on the led Could you please help me get the unit runing
    New Friend:
  • 9 Answers
For this you have to go into the the board located in the right side of the unit if your problem is what i think it is crosswire on the board.
Posted on Jun 03, 2010
Klimaire KSWG012H113 Split System Air Conditioner
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
Jul 24, 2016 | SNK Klimaire KSWG012H113 Split System Air...
Remote control malfuction
04Feb14
In some states and provinces of Canada, the Lloyds 'remote' CANNOT be programmed into cable vision providers!!!!!!!!!!
One provider 'Shaw Cable' has never heard of Lloyds.
What's up with this.....having to use Lloyds remote to adjust volume and mute, while using Shaw's remote to channel change.
That's just awful. Archie Bunker has it bedda.
Feb 04, 2014 | Klimaire Universal Mini Split Remote...
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
Fan will only blow on low when heat is on
your fan most likely is wired for low speed for heat which is common. this should be determined when furnace is set up properly. motors that aren't modulating motors and are multispeed motors typically have low medium and high taps that come off the motor and go to the corresponding relay on the board. low and medium speeds are used for heat and high and medium speeds are used for cooling. but only one speed for heat and one speed for cooling many times medium never gets used. im not familiar with klimaire is this a mini split system and not a regular air handler. cause speed control should be adjustable from the remote. if its a split but if not reaching desired speed due to a malfunction in the units could cause it to run low speed just to maintain the temperature exiting the indoor unit.
Oct 21, 2013 | Klimaire Heating & Cooling
I have a Klimaire 16 Seer Dual Zone Mini Split Heat Pump AC and the outside unit fan/fan motor have stopped working where can I replace this at? I live near Dallas Tx surely there is something nearby?
You should check the fuses and breakers it might not be something that expensive, it could also be the controller for the outside unit that is bad. Google kllimare dealers and your zipcode.
Sep 02, 2013 | 18,000 BTU KSIM DUCTLESS MINI SPLIT...
Do I have to use a wiring harness for Klimaire multi-zone mini split or can I hardwire into the power between studs? Are there any cables that need to run from the wall unit to the outside compressor
The specs on that unit dont list the wattage of the head unit. I would be very careful about just tapping into the wiring in the wall. First off you need to know what the wire size is in the wall. The second thing is that you have to enclose it in a box if you tap it. The outside unit is another issue. It has to have its own source of wiring and it has to meet specs for outdoor use. So you will have to run a circuit just for that. No matter how you do this. You should have an electrical inspection done before it is finished.
Mar 23, 2013 | Heating & Cooling
After installing my Klimaire 30912-H216 mini split, one of the three evaporators is cooling but not as much as the other two.
actually the hi side smaller line should be hot to the touch and the low side larger line should be cool or cold, sounds like a low charge without any further information, the small line coming off the compressor is the liquid compressed it should be hot, the large line low side returning to the compressor is the gas after the coils and returning it should be cool or cold depending on load
Jul 06, 2012 | Heating & Cooling
I have a Klimaire 1200 btu heat pump split system brand new I installed myself (this is the third one I have installed). It worked fine for a couple of weeks and then the outside unit began to cut off...
Often on those types of units they use a sensor to sense the temperature of the return line to prevent liquid floodback...
I am thinking the either there is a shot of really sold coming back soon after startup or that the sensor is bad and is being too sensitive, shutting the unit down when it really does not have too...after it does this once it is more stable and it does not happen again til the end of the cycle...
Actually I think that it may be overcharged and theat is what is causing the problem...
Do you have a very short line set on thsi unit??
Was it setup with a precharged unit and lineset??? or did you build the lineset and then charge it your self???
heatman101
Dec 08, 2010 | SNK Klimaire KSWG012H113 Split System Air...
Cfm Klimaire KSWG009H113 Split System Air Conditioner Logo
816 people viewed this question
Top Cfm Heating & Cooling Experts
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Thomas Woodburn
Thomas Woodburn
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
