Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Ice maker is not working
My ice maker is not working, the water gets frozen before it gets to where the cubes are actually made.. what can i do?
    Novelist:
  • 77 Answers
If I understand the problem correctly, it sounds like there is ice frozen in the tube that the water flows through just before it comes into the ice maker. If this is the case, I have the solution.
This problem is caused from a bad water valve. The water line that connects to your refrigerator hooks up directly into your water valve. The way it works is this. The water valve keeps the water pressure to OFF. Whenever your ice maker needs water it simply asks the valve to open and it does. The problem is this. The valve has malfunctioned and isn't totally shutting off anymore. This lets a tiny bit of water through. This water slowly makes its way up the water line into the freezer where it freezes in your tube :) You just need a water valve! With a model number I can give you an average price. Chances are it will run anywhere from $50 - $100. Just depends on where you get it. This is also a very easy thing to change!
Posted on Jun 02, 2010
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Ice maker is frozen
If ice is frozen in the cube trays and does not come out, this can be caused by an open tray heater element or a cam mechanism that is not working and not turning on the heat element. Replacement of parts is in order. But lots of places ripp you for parts so when you figure in the cost of the part and shipping it is often best to just go out and get a new ice maker for about 40 bucks on ebay.
Aug 29, 2014 | Whirlpool Refrigerators
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Sub zero 532, ice maker issue. water enter the cube bin freeze into a block of ice with the cubes embedded. What is the cause of this issue?
There is a few things that you will need to check to isolate the problem. this first thing is locate the fill tube where the water comes into the ice maker. What you are looking for is any ice frozen inside causeing an overspray of sorts. If that checks good, then the next thing is look at the icemaker itself. Look at where the water goes to and freezes. Is it completely full of frozen water? if so then the water valve is sending too much water either because the ice maker called for it or the valve stuck and didn't close when it was supposed to. If its not full, look at the bottom of the ice maker, checking if there are any cracks allowing water to fall into the bin. My personal opinion though would be to change the ice maker and the water valve because of the age of the machine. the bad part is the actual icemaker for that model has been discontinued but I believe you can use a whirlpool style that matches, comes in a kit that has both the water valve and icemaker, and cost almost half the price as the original. that part number is 1129313
May 21, 2012 | Refrigerators
The ice cube maker just quit working. Why?
This could be for a number of reasons. The most common reason is that the water inlet pipe to the ice maker has frozen up, in which case derfost the freezer and start over or that the actual motor itself has gone- replace motor- or there may be a problem with either the control board or user board cicuitry, in which case you will need to replace the specific board
Jun 04, 2010 | Whirlpool GS6NBEXR Side by Side...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Frozen water in ice tray
You do need to thaw the ice maker out completely. I always remove it but that may be more than you are up to. You can also try a hair dryer on it to thaw it out.
Feb 26, 2018 | Whirlpool GS6NBEXRB Side by Side...
Water is not geting to the ice cube maker, it is
Look inside the water tube to the icemaker. It may be frozen. If so, thaw it out.
If not frozen, replace the water valve.
Mar 19, 2009 | Refrigerators
Frigidare ice maker making slabs of ice, not cubes
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Nov 16, 2008 | Frigidaire Dryers
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
73 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
