Question about GE Profile PSS26NGS Side by Side Refrigerator
Water is leaking out from the bottom of the freezer
My GE Profile, there is a puddle of water at least twice a day on the floor in front of the freezer.
The inside bottom of the freezer under the basket there is a frozen puddle of water. It looks like it is leaking from the back of the inside of the bottom of the freezer but not sure what it is.
    Guru:
  • 1,524 Answers
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Posted on Jun 02, 2010
We have a GE tfx22prxd aa side by side. There is water that runs out the bottom of freezer door. Happens about once or twice a day and leaves small puddle. There is a thin layer of ice laying on freezer...
Because the drain hole is probably frozen and the water can't drain out. Gain access to drain hose by pulling fridge out removing back cover and locating drain line. Remember how drain line is positioned and pull it off. Now open freezer door and pull the bottom container out and look toward the rear bottom of freezer. That's the drain. In order to fix it i usually melt the top part enough so i can start pouring hot water in it and be trying to clear with icepick too. When done reattach drain line and that's it.
Sep 25, 2017 | Refrigerators
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Water puddling in bottom of freezer, then freezing,then more water on top of that ice running out on floor
sounds like the drain hole in the back of the freezer is froze over or blocked with something
Jun 07, 2009 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE Profile Refrigerator with large puddles of water on floor.
First, your most pressing issue: the water on the floor.
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from coming out the freezer door and leaking onto your floor.
Now, for issue #2, your water dispenser: If you take the front grill off, you will see a plastic tube going through the hinge. There is a coupler, usually a insta-push type just before that. If you push on the collar of the fitting toward the center of the fitting while pulling (not real hard) on the tubing, the tube will come off. Now, try the water dispenser to see of any water comes out the disconnected tube. If yes, comment back to me to see how to fix this, if no water comes out, you most likely have a bad water valve. Reconnect the water line by just pushing it back into the fitting. Disconnect the outlet side of the water line at the water valve and try the dispenser again. No water out the valve almost always will be a bad valve. (there are rare exceptions) Water out valve now when dispenser is pressed equals a frozen water tank or water filter in the fresh foods compartment. Issue #3, your uncovered foods: All the cooling for a refrigerator takes place in the freezer compartment, and some of the cold air is circulated into the fresh foods compartment to cool it. As the air is circulated throughout the entire refrig / freezer, air picks up and transfers odors to uncovered items, including ice. Cover foods and use an open box of baking soda to help absorb odors. Issue #4. (was there a #4?) Oh yes,..... why are you dealing with this? Tell the landlord to have a service company come and check it out. You don't pay the service company, you pay the rent. Landlord is responsible for the repairs.
May 17, 2009 | GE Profile Performance 25.2 cu. ft....
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile TFX27PF/TFT27PF Refridgerator
There is a line from the defroster catch pan, up under the freezer, to an evaporation pan, down under the bottom. If it becomes clogged with dirt, bugs, whatever, the catch pan will overflow, and leave a puddle on the floor. Find it and unclog it.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
GE Profile PSS26NGS Side by Side Refrigerator Logo
690 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
