Question about Acer Aspire One PC Notebook
My Acer netbook will not boot all the way. The screen showing that Windows XP is starting shows up, but then it stops at the screen that asks me whether I want to go into safe mode. I tried pressing F8 and disabled automatic restart so I could read the codes on the blue screen. Codes are: 0X00000073 (0X00000001, 0XC000017D, 0X00000001, 0XF749BBB8)
  • 428 Answers
Hi, STOP Error 0x00000073: CONFIG_LIST_FAILED STOP error 0x73 means that one of the top-level registry keys, also known as core system hives, cannot be linked in the registry tree. STOP code 0x00000073 may also display "CONFIG_LIST_FAILED" on the same STOP message.
This can be either SAM, SECURITY, SOFTWARE or DEFAULT. One common reason for this to happen is if you are out of disk space on the system drive (in which case param 2 is 0xC000017D - STATUS_NO_LOG_SPACE)
This is a serious situation. What has happened to the PC? Was there a power failure? Sudden restart? I cannot say exactly that this is the problem. We have to analyze further.
Here are some steps and information to help you.
First of all make sure you have ENOUGH DISK SPACE in your SYSTEM PARTITION (Volume). STATUS_NO_LOG_SPACE means that logs and hive enumeration is not possible due to lack of the space. System drives has page files on it as well so First thing you have to do is to save some SPACE. If you have Windows DVD (or CDs - use CD1) just insert it and boot from CD/DVD. Go to Recovery Mode (Key is R). In the recovery mode Type DIR. If you receive an Error you have to type chkdsk PartitionName: /f /r As an example if your system drive is C that would be chkdsk C: /f /r ( Spaces between C and /, /f and /r ) Then the disk will be checked for bad sectors. Partition table will be fixed to normal.
If you do not receive an error and if you could see the files: Delete some files using DELETE command. (Use with caution - Try delete ? or delete /? for a list of OPTIONS). Create some space (If you use Vista make sure you have at least 1GB Empty Space. A calculation. You have to have at least 1GB + Space for the Page File. Page file uses 1.5 x your RAM Size GB space.). Then Boot the machine and check. That should work.
This post has two parts since its too long.
Posted on Jun 02, 2010
  • 2 more comments
  • Tharinda
    Tharinda Jun 02, 2010
    Actually 3 posts
    Using Vista Disk: (From Microsoft Support)
    Try Startup Repair from the Recovery Console (if you have one) or from a Vista disk - if you do not have a
    Vista disk you can borrow a friends (they are not copy protected) or make one. Also your System maker will sell the physical disks cheap since you already own Windows.
    This tells you how to access the System Recovery Options and/or with a Vista Disk
    http://windowshelp.microsoft.com/Windows...
    Try StartUp Repair from Recovery Options and/or a Vista disk.
    How to do a Startup Repair
    http://www.vistax64.com/tutorials/91467-...
    Also from the COMMAND PROMPT of Recovery Console (if possible) or a Vista disk
    SFC /scannow
    Hit Enter
    and after that runs
    chkdsk /f /r
    Hit Enter
    Retry Startup Repair after Chkdsk.
    If needed after those you retry System Restore from the Recovery or Vista disk.
  • Tharinda
    Actually 3 or more parts
    This tells you how to access the System Recovery Options and/or with a Vista Disk http://windowshelp.microsoft.com/Windows...
    How to do a Startup Repair http://www.vistax64.com/tutorials/91467-...
    SFC /scannow
    Hit Enter
    and after that runs
    chkdsk /f /r
    Hit Enter
    Contd...
  • Tharinda
    Just ignore the second or third (both are the same)
    How to Do a System Restore in Vista http://www.vistax64.com/tutorials/76905-...
    If you need to make repair disks - these help repair Windows not re-install.
    How to Make a Bootable Disk in Vista http://www.brighthub.com/computing/windo...
    Download: Windows Vista x64 Recovery Disc http://neosmart.net/blog/2008/download-w...
    How to Make a Windows Vista Repair Disk If You Don’t Have One http://www.howtogeek.com/howto/windows-v...
    If you are unable to do it please contact once again.
    If this solution is helpful to you kindly please comment and provide a testimonial as well.
    Thanks for contacting Fixya!
  • Tharinda
    Sorry I didn't see that you use Windows XP. Anyway the solution is the same for Windows. If you have a recovery disk you can use it. Or follow the steps.
    If you are able to boot you can check the Event Viewer and / or do a System Restore.
    And scan your machine for Viruses as well!
I pressed f10 lots of times and my internet just stopped working ,i wanto reset my klaptop to factory settings please can u help
All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows xp factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
1. have the netbook connected to its AC adapter which is plugged into AC power line
2. power on the netbook and watch the screen as it starts up
3. when the acer logo is showing, hold down the Alt key and press F10 repeatedly
4. until screen indicates Acer eRecovery is loading
5. once eRecovery is loaded, follow the directions given on the screen
May 08, 2011 | Acer Aspire One PC Notebook
I have a acer netbook.when i press standby or close the lid then it become go to sleep mode but problem is creating when press enter button then i cannot start any program or it go to hang position. my...
If your windows xp is not genuine, it likely has been corrupted. This would also explain why you cannot start any program. All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows xp factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
May 08, 2011 | Acer Aspire 5315 Notebook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
I forgat my. Administration user account and I need to axces to my acer one
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ++ keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2nd Method:
A. Boot using Windows XP Setup CD and follow the instruction like Accepting EULA, etc.
B. When it asks to repair your existing Windows installation, accept it and press "R" to run the repair.
C. Setup will start repairing your Windows and will start copying files, etc.
D. After a few minutes setup will restart your system and when it restarts don't press any key when it shows "Press any key to continue..." otherwise Setup will start from the beginning. Don't press any key and setup will resume where it left.
E. Now it'll start doing other tasks and will show a small progressbar with a few details in left side.
F. Look carefully at the details and when it shows "Installing devices", press +F10 keys in your keyboard.
G. It'll open a Command Prompt window. Now type nusrmgr.cpl and press .
H. It'll open the same "User Accounts" window which you see in Control Panel.
I. Now you can remove or reset any account password without any problem.
Dec 03, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One loops on start up screen. All it does is show the acer logo, then shows the ''windows was shut down improperly'' screen with all those options and then goes to the windows xp start up...
Try tapping F8 when the acer window shows, when it shows the muliboot option, scroll down to "Last Known Good Configuration" and hit enter. If it does not boot normally, you will have to get an external dvd drive and boot off the drive with a windows installation disc to perform a repair.
Jan 07, 2010 | Acer Aspire One PC Notebook
To stop acer logo before starting windows xp
Well, Firstly this might be a extreme case but is to reformat your hard drive removing any manufactures partition, and reinstalling the Operating System, but what i would do first is the go to start---run---(type this command and hit enter)"msconfig" the system configuration window should pop up. Go to the boot tab and place check mark in the box which says "No GUI boot" you mat also change the timeout seconds there too. hit apply then OK and reboot your system.
hope this works for you. let met know.
Oct 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Just purchased acer aspire one 150-1786 netbook
You say you just purchased it, It must be under warranty, take it back. If its not under warranty it could be a number of things. removing and replacing the ram is the easiest thing to do. Does anything show up on the screen when you turn it on?
Jun 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One  PC Notebook Logo
528 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
