Question about GE DBXR453EV Dryer
How do I replace the starter switch for a ge dryer DBXR453EV0WW Dryer will not start. I have purchased the part. I need instructions how to replace it.
  • 23 Answers
First unplug the unit...VERY IMPORTANT...then there should be 4 screws on the back panel of the unit and 4 on top take them all out and the knobs. then you should have two screws that hold the switch in unless it is a clip in but i believe there are screws. and change one wire at a time so you do not cross wire anything
Posted on Jun 02, 2010
What mosel can I purchase to replace teh GE wsxh208a washer so I can stack teh dryer that still works
Sorry You 'll have to remove the dryer to allow access to the washer's inner components. It takes two but the dryer isn't that heavy.
Oct 24, 2014 | GE WSXH208A Front Load Washer
Why does my GE 7 Cycle Dryer makes noise when I turn the start button, but does not run the dryer
The start button just engages it to run. See if the wires are still on it. Turn off your breaker, then back on. If still not working, then replace starter switch.
Mar 12, 2013 | Dryers
GE Dryer GFDN110ELWW hums loudly and won't start
The start capacitor is built into the motor and you will need to replace the motor. Here is the motor if you should need it.
Nov 24, 2012 | GE GFDN110ELWW Electric Dryer
The dryer won't start. The electrical outlet has power, and an electric test meter shows power at the starter switch on the dryer. But it still won't start. I believe the problem is a blown internal...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2010 | GE Dryers
Hello. I have GE electric dryer DBXR463EG6WW. The starter switch does not work. I am getting power to the dryer. The light goes on when the front door is open, so not a power problem
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 29, 2010 | GE DBXR463EDWW Electric Dryer
Starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Jan 04, 2010 | General Electric WHDRR418GWW Dryer
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
My dryer wont start at all...
Did you check the door switch. If it is open (not making contact) the machine will not run. Could be the motor start/run switch which could be stuck with lint (clean it) or worn out ( replace the motor).
Sep 18, 2009 | GE DSXH47GGWW Dryer
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
I have the same dryer doing the same thing. Open the door and take the two screws out and lift the top. Remove the two screws that hold the front on. Remove the front. On mine both the plastic parts that stay on the front when it is removed are cracked and needing replaced. I found over 20 buttons that the dryer had pulled off clothes stuck in the front door. I'm sure if it will be cost effective to buy both these parts or not.
Jan 13, 2009 | GE DBXR453EV Dryer
Dryers Logo
498 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
