Question about Sub-Zero 632 / S
I have a 3151P under counter ice maker. Installed today, making ice but ice melts after dropping into storage bien
    Guru:
  • 1,524 Answers
Check temperature of bin.
Posted on Jun 02, 2010
Testimonial: "Good suggestion. Will test the unit to determine temp."
My Icemaker won't keep the ice once it makes it
What make and model of ice maker do you have?
Is the unit making ice? If so, about how much?
Most commercial bin type ice makers are not engineered to maintain the ice once it drops into the bin. Older ice is intended to melt and the water should drain out of the bin as new ice is deposited on top.
It may be that you are consuming ice at a rate greater than the unit is designed to produce ice, or that the unit is not set to the highest ice production rate (if adjustable).
Alternatively, if the inside of the bin is hot (warm) you may have another problem with the unit (e.g., gasket leak). Was the unit previously working? If so, are you aware of any events that took place just prior to the change?
Some units have a defrost or a cleaning mode, which will actually generate heat inside the unit. Make sure the unit is set to the correct mode.
Feb 12, 2014 | Manitowoc QM30 Under Counter Ice Maker
Ice maker not dropping ice
Need more info. Are there ice cubes in the storage section just behind the freezer door? You may have turned the ice-maker OFF. When your depress the ice flipper, does the motor run behind the door? The motor may be burned out or the ice cubes in the storage section are so melted together in a giant glob that the agitator cannot turn.Or, maybe someone turned OFF the water supply.
Aug 10, 2012 | Samsung RF4267HARS Stainless Steel French...
My u line under counter ice maker (bin, not clear ice) will take forever to make ice. Once it starts to make ice and drop it in the bin, several hours later it will stop making ice and the made ice will...
Can you tell me the model? If its a bi series then it should make ice every 45 min. temps should be 10-15 degrees in bucket. If its a combo then it could take 24 hours to make 1/2 of the bucket.Should be the same temp in your bucket.Make sure you dont have heavy frost in the freezer, Make sure the condenser fan is running and clean.If the temperature in freezer is alot warmer than this and everythng is running then it could be a leak in the system. If its colder than that then set the thermostat to a warmer temperature
Aug 06, 2009 | U-Line Icemaker
Viking under counter ice maker stopped making ice... ugh.
This unit senses the "freeze plate" temperature to decide when to go into "harvest". Either the the temperature sensor (most likely called an evaporator thermsitor) is lying to the control or the plate is not getting cold enough due to a sealed system issue (usually a bad hot gas valve). If you carefully loosen the front grill (staying clear of the wires going to/from the ON/OFF/CLEAN switch) you can see the hot gas valve near the center in the bottom of the mechanical area. If the copper tube coming out of the bottom of the valve is cold during the freezing cycle...it is bad. If not, I would try the thermistor first. If you do not feel comfortable doing this, you should contact a servicer to diagnose the unit for you. Good-Luck.
Apr 25, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Under counter ice maker water pickup problem
Most likely your plastic curtain is not keeping the water in the sump area. ( I'm assuming it makes round cubes)? Look under the sump for any dripping if its a pretty steady drip replace your water curtain and the holder that's with it.
If you have a cutting grid type ice machine this is all together different and I need to tell you separately about that.
Jan 01, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice jams in KUIS18NNJB Kitchenaid under counter ice maker
There are 2 sets of wires on the cutting grid that are perpendicular to each other. Electrical current passing through the wires creates heat that melts the ice. The first set cuts one direction, then the ice strips drop onto the second set that cuts the strips into cubes. Remove the cutter grid and check if the wires are broken. If they are, electrical current can't pass through the wires, so no heat. Restringing kits are available to fix this. If the wires aren't broken, you'll need a voltmeter to see if current is reaching the wires. If it isn't, then the transformer has likely failed.
Dec 13, 2008 | KitchenAid KUIS18NNT 18" Automatic Ice...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Sub-Zero 632 / S Logo
358 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
