Trane XL13i outside unit: fan won't come on, unit has loud 60 cycle buzz. I replace the starter capacitor, but no help. What should I look for next?
  • michaelp7xd Jun 16, 2010
    I replaced the fan motor, but no good. I checked the contactor, and found that it kicked on but there was no voltage across the contacts. I discovered that a bunch of ANTS had crawled their way into the contactor, and the 240VAC fried them onto the contacts pretty well. After buying and replacing the starter capacitor and fan motor, it turned out that all I needed was to clean and file down the contacts on the contactor. AC runs like new now!
    Guru:
  • 1,524 Answers
Sounds like a bad motor winding.
Posted on Jun 02, 2010
How do I fix my Trane air handler to keep it from turning off about 20 seconds after being commanded to turn on?
Some units require both a start and a run capacitor. It's possible the wrong capacitor was replaced. It's also possible to add a run capacitor to a system to keep the fan running. There is an outside chance the bearings in the fan motor are worn to the point it's time to replace the motor.
Mar 29, 2015 | Heating & Cooling
Turn on AC but outside unit fan doesn't move
Either a very bad Capacitor, or the fan belt came loose and the motor is just spinning
May 26, 2014 | Empire DV-215 Direct Vent Natural Gas...
Trane XL13i outside fan won't come on
Bad capacitor it needs to be replaced
Jul 26, 2012 | Heating & Cooling
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
Aug 23, 2011 | Heating & Cooling
Trane xe 1000 - 1/4 fan motor went bad - I replaced it with a used 1/3 from another trane unit - it had same wiring harness etc everything starts, runs, cools -cold air - but only for about 5...
Did the 2 fans have the same rpm. If there is not enough airflow through the outside unit the compressor will shutdown on high discharge pressure. Also make sure the fan blades are positioned right if there is a shroud for them. Did the other motor have a capacitor with it or did you use the 1 from the smaller motor. Sometimes the motor data plate will tell you what size capacitor you need. Let me know what you find.
Aug 24, 2010 | Heating & Cooling
Outdoor fan does not come on
most likely it the the cap that is bad. Is this in heating or cooling mode?
Jun 03, 2010 | Heating & Cooling
Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
Aug 19, 2009 | Heating & Cooling
Heating & Cooling Logo
959 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
