Question about Homelite ZR10926 16 Chain Saw
Oil leak when running. - Homelite ZR10926 16 Chain Saw
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain from the engine. Clean the entire area where the bar fits to the case. Start the engine--oil should ooze out of the side port only. If ok, clean the bar drive-end small oil-channels that bring oil to the chain groove on each side of the bar. Also, clean the entire chain groove. Refit the bar, chain, and cover leaving the fasteners finger tight. Turn the chain adjuster CW until the chain comes up to the bar, but not so tight that the chain can't be turned by hand. Tighten the cover fasteners and recheck the chain tension. Start the engine and run the bar tip at speed near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Posted on Jul 14, 2010
What would leak oil onto the starter
the oil leak could be a bad valve cover gasket needing replacement, a head gasket leaking oil, a leaking intake gasket and oil running down along the engine block and dripping. it could be an oil pressure switch that is leaking. it is near the starter while driving or engine running can spray oil onto the starter. unless the oil leak is very bad and has been leaking a long time onto the starter will not cause it to act like a dead battery even then not likely. have a starter draw test down to check condition of the starter.
Sep 23, 2014 | 2003 Ford Taurus
Oil in coolant
Sounds like an intake gasket leak. Oil can leak into the cooling system without coolant leaking into the oil.
Jan 17, 2014 | Chevrolet Uplander LT Cars & Trucks
Why is my car leaking oil
its common for some automakers to leak oil, run badly, break often, & otherwise be a plain hassle............I would suggest reading consumer reports before buying new or used cars.
Jan 23, 2012 | 1996 Volkswagen Jetta
Leaking transmission fluid
TRANSMISSION FLUID LEAKS,CAN BE FOUND AROUND PAN GASKET.CHECK PAN GASKET,IF IT LOOKS WET AND YOU SEE FLUID DRIPPING AROUND THE EDGE OF OIL PAN, REPLACE PAN GASKET, WHILE YOU REPLACING PAN GASKET REPLACE TRANSMISSION FILTER WHILE OIL PAN OFF.IF TRANSMISSION OIL PAN NOT LEAKING, CHECK TRANSMISSION OIL COOLER LINES GOING INTO RADIATOR YOU WILL LOOSE A LOT OF FLUID THERE ALSO TORQUE SHAFT SEAL WILL CAUSE HEAVY FLUID LEAK WHILE ENGINE RUNNING CHECK OIL COOLER LINES AND LOOK AT THE TORQUE AREA WHILE ENGINE RUNNING YOU WILL SEE FLUID POURING WHILE ENGINE RUNNING THE OIL PUMP PRESSURE WILL PUSH FLUID OUT AT THE LEAKING AREAS.
Aug 01, 2011 | 1991 Nissan Stanza
I have oil leaking out my 491056 oil filter on my mtd lawn mower. I have not changed it in about 8 years could that be why it is leaking? or ? It is pretty much pouring out now. Was a small leak now a...
Change you oil and while you are at it change the filter. Do not run until you have completed. You risk engine damage by loosing too much oil while running it.
Jul 24, 2011 | Briggs & Stratton 491056 492932 Briggs ...
Engine oil leaks rover 25 1398cc engine petrol above and around oil filter. about egg cup full intermitently every few days
possible cause of leaks the oil filter the oil pressure switch oil could be running down from cam cover leaking gasket; could be camshaft oil seal best to clean oil run car try to pinpoint where it is coming from .
Jan 17, 2010 | 1995 Land Rover Discovery
Gearcase is leaking oil
What brand??? Whirlpool ,kenmores leak through the front shaft by coulpling. It will still run with low oil, it may get oil on clutch wich can make it slow spin.
Ge's old and new leak oil and can run for a long time with no oil. They will get loud and scize up after awile. Old maytags leak and keep on running. New ones drop dead.
Run yours till it dies, replace the trans with a new one or buy a new washer. There is no fix for any leaks, just replace transmission or washer.
Nov 22, 2009 | Washing Machines
My 2001 chevy cavalier has a oil leak and I can't
You can buy a florescent dye to add to the oil and a light to make the dye really shine.
Clean the engine with "brake clean" from a spray can at the oil leak areas ....then run the engine.
Check for the start location of the leak.
Start with a short run time ....... then longer run time if necessary until the leak(s) show.
With or with out the dye ......this brake cleaning method should help locate the leak(s).
Oil leak locations could be...in order of the most common on your car are........valve cover gasket,oil filter,oil pressure sending unit,drain plug,oil pan gasket,crank pickup sensor,rear seal.
Oct 14, 2009 | Chevrolet Cavalier Cars & Trucks
1994 GMC Safari Oil leaked out for no reason. Put more oil in...look under van and oil is leaking like a water fall. Turn Van off oil leak calms to a trickle. Other than the oil water fall the van runs...
Check the oil filter adaptor bracket. My 1993 Safari had the same problem, and the adaptor bracket and seal were bad. Replacement fixed the leak.
Dec 31, 2008 | 2002 GMC Safari
Homelite ZR10926 16 Chain Saw Logo
276 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
