Question about Brother LS-2125 Mechanical Sewing Machine
Have a new machine and trying to thread for the first time. Thread take-up lever does not move into a high enough position for me to thread cotton through the eye. Help please.
    Sniper:
  • 53 Answers
You should be able to turn the hand wheel (on the right side of the machine) towards you and you should see the take up lever on the top left. It does not stick above the machine.
Let me know if you need more help,
Chris
Posted on Jun 07, 2010
    Sergeant:
  • Brother Expert
  • 455 Answers
The thread take up lever has a slice in the arm that will allow the thread to pass into the eyelet of the take up lever. You do not need to "thread" through the take up lever. Just raise it to the highest point, and thread always making sure that the bobbin is inserted into the bobbin case spinning in the correct direction.
Cheers,
Embroidery Services
San Diego, CA
Posted on Sep 25, 2014
I have a model bl 4000.Lots of problems with thread bunching, beaking thread, thread slippin out og thread take-up lever
Ooh, boy. You are having some problems.
First thing I suggest:
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread the machine from the beginning.
Verify the thread path is correct.
Remove the bobbin case & check that the bobbin is loaded (turning) the correct direction and the thread is threaded through the bobbin tension.
Set the top tension to the midway point--this can be tweaked later.
Also, you might try changing the brand/type of thread you are using. AVOID old or bargain bin threads!
Confirm that you are using the correct needle size & type for the fabric you are stitching, ie ball point needle for knits, size 70 needle for light-weight fabrics like chiffon, silk. Be sure that the thread is not too big (or too small) for the needle eye.
Breaking thread could result from several things, ie tension too tight, the thread is too large for the needle eye, the fabric is too coarse or tightly woven (try a top stitch needle). or there could be a burr or rough spot somewhere in the thread path that is snagging and breaking the thread.
All About Needles
For the thread jumping out of the take-up lever, this occurs on a lot of older machines but I wouldn't think it likely on yours. Makes me think there is something holding back the top thread. If you rethreaded (as described above), it may have taken care of this problem. On older machines, I've actually resorted to folding a piece of tape over the opening in the take-up lever so the hole is closed and the thread can no longer escape.
There could also be some gunk or broken thread stuck in the tension disk. If you continue having problems, try soaking a length of cotton perl thread with alcohol (wring out the excess). Then with the top thread removed from the machine, RAISE the presser foot, loosen the top tension all the way, and gently pull the length of perl cotton DOWN through the tension disk a few times. This may remove any gunk or thread that may be stuck.
Jul 14, 2017 | Sewing Machines
I have a Singer 7466 and recently I developed an issue with the thread stripping and then breaking.
three possible reasons
old cotton will break or shred easily so get brand new cotton
next is eye size of the needle
a small eye with a heavy gauge cotton will not allow the cotton to pass easily
next is needle /hook timing
out of time allows the hook to pierce the needle thread and create the problem take it to a service centre for a check of the timing
Jan 11, 2017 | Singer 7466 Mechanical Sewing Machine
The take-up lever does not raise up high enough to pass the thread through easily. Any other way of doing this?
make sure that the needle is at the top of the stroke
if you have to you can let the foot down and that should give you ample room to thread the eye of the needle
if not the needle timing may have slipped in which case it will need a service or the needle may not be up in the holder far enough
Nov 02, 2015 | Sewing Machines
Machine wont sew cotton keeps coming out of needle tried everything
Do you mean cotton thread won't work in the machine ? Does polyester thread work ?
Some thread brands are not as good quality as some others. Not knowing what brand thread you have, it is possible the thread itself is causing the problem. .
If other types of thread work in this machine, it is most likely either the particular spool of thread or the brand being low quality that is the problem. I would try a brand new spool of a high quality cotton thread to see if that helps.
Oct 02, 2014 | Brother Sewing Machines
How to thread euro pro x
Cotton reel on top of the machine, make sure presser foot is up, make sure takeup lever is at the top, take the thread to the left ot the machine going through the guides at the top, bring the thread towards you and straight down and round the big cotton guide and straight back up, right to left through the takeup lever then bring the thread straight down through any guides and then thread the needle
Oct 26, 2013 | Euro-Pro Sewing Machines
I have a brand new Brother XR1300, but I can't
use the "needle Up/Down" button to raise the needle - when i first got it i turned the wheel by hand, but it was never in the right position
Dec 29, 2012 | Sewing Machines
Thread take up lever does not raise high enough to thread.
you don't thread it like we did the older machines... it has a slot... just come up the right side over and down the left side... it will slip into place.
Dec 14, 2012 | Brother CS6000i Computerized Sewing...
Screeching noise
have you tried a new needle--flat side to the back of the machine
check to see if the thread has come off the thread take up lever
it's also possible that there's something wrong with the motor since it sounds a bit loud
it probably needs to be serviced
Feb 23, 2012 | As Seen On TV Mini Mechanical Sewing...
After tangle in thread and jamb, feed dogs do not rise high enough to move fabric with lever in correct position. How do I adjust for proper rise?
Have you moved the lever shown on page 12 or 13 in your manual? I looked at your manual at www.singerco.com and it showed a lever in the rear of your machine to move. If, you misplaced your manual, download one for free from the Singer site.
Nov 10, 2010 | Singer 7426 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
4,113 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
