Question about Magellan MapSend WorldWide Basemap (980640) Maps Software
When I launch the Mapsend World wide basemap app I get an error message asking me to insert the CD with the volume Label MSendWW_100d and retry or cancel. Even with CD in the response is the same. The volume label on the CD is correct and dvd drive is operating good. I've also installed the 1.3 patch.
  • ppittard Jun 02, 2010
    Tried installing from back up cd, all files appear to be there but can't get past the mapsend autorun file, keeps coming up with warning message.
  • ppittard Jun 03, 2010
    It told me I'd been doing everything I could to get it to work
    Guru:
  • 302 Answers
Is it so that the CD has a lot of scratches?. If so maybe the drive cannot read it properly. Try cleaning the CD with liquid soap and water. Be sure not to create any more scratches on the CD during the process. Wipe it with a soft cotten cloth and dry it THOROUGHLY. Try it again if it still doesnt work then maybe there are too many scratches. To check whether your drive is reading the CD properly copy all the contents of your CD to your hard drive. This will ensure that the drive is able to read every peice of data. If this is working and still you are getting the same error then it is a software problem. Try uninstalling and re installing the application.
Posted on Jun 02, 2010
  • Mohsin Idrees
    Mohsin Idrees Jun 02, 2010
    May i suggest that you try installing the software on another pc/laptop to verify that the problem is in your PC or not. It can be any thing a corrupt Windows or an irrelevant registry entry etc. If it turns out fine in the other PC/Laptop then you need to fix your PC most probably by re installing Windows.
    thanks for the suggestions but no still no progress. There are some scrathces on the CD but even copying across the data to the hardrive and running it from there gets me the same result only the location is different.
    I've loaded it onto another pc with the same outcome. Given the price I think I'll just purchase another version and be done with it.
    'thanks for your help
I have this same problem and have not found a solution. Suspect the CD was coded wrong by Magellan. Have tried on 2 XP computers and one running Win 95. All give the same error message before the program starts. The CD came with a SporTrak Map gps from FactoryOutletStore. Magellan has discontinued the unit and no longer supports it.
Posted on Sep 03, 2010
  • 4,281 Answers
First try to repair it.
for that open my compute then open the disk and run setup exe then chose repair option then it repairs it.
then you can launch Mapsend .
If still same issue then download revo uninstaller from below link.
Click here
Then install it in computer then run revo then select Mapsend and uninstall remove all reg keys when it ask for remove.
Then reinstall it from disk then it will work fine.
Let me know if you need further assistance.
Thanks for using FixYa.
    Thanks for the advice Krish but still no good. I've followed all the steps you recommended but still get the same warning message when the cd is inserted.
  • Download it's patch from below link then istall then check.
    Click here
    Give me exact error when you try to install software from disk.
Xp-800 cd/dvd printing
The tray is for the DVD or CD itself, not for a label. The printer prints directly on the CD or DVD, you must use ink jet compatible blank disks, the white ones with no printing. You don't need a tray to print the label.
Oct 14, 2014 | Epson Expression Premium XP-800...
A message keeps telling me to insert the correct CD and retry?
It sounds like your game is installed "compact' which means that the main files for the game are loaded on your computer's hard drive but other files, such as graphics that are only used occasionally, but still needed for game play, remain on the CD. Either insert the game CD in the drive or reinstall the game and look for a prompt asking you to choose between full or compact install, and choose full.
Aug 19, 2012 | Ubi Soft Entertainment Playboy: The...
I have 2 errors in cafe world..trouble all the time with freeze up..retry comes on just when i have food to take off and lose it all.can u please fix this!!!!
i have 2 errors in cafe world..trouble all the time with freeze up..retry comes on just when i have food to take off and lose it all.can u please fix this!!!!
Feb 24, 2011 | Facebook Apps
FATAL DISK ERROR, RETRY
I need a support from you
Thanh you very much!
Nov 25, 2008 | Sony CDU4811 48x IDE CDROM drive...
Problemi con explorist 500
Ciao, mandami una email a casa1111@libero.it altrimenti tramite questa via ci mettiamo fino all'anno prossimo. hai messo una basemap europea sulla SD card? nella directory "Backgroud maps"? se hai fatto così avrebbe dovuto sentirtela. Se in ogni caso metti la basemap europea nella directory USBTRANS della SD card dovrebbe caricartela nella memoria interna del GPS (dopo il caricamento non è più presente nella SD card, per cui se devi ripetere l'operazione devi rimettercela).
Ciao
Alberto
Oct 04, 2008 | Magellan eXplorist 500 GPS Receiver
Samsung SGH-D600 "Install error"
you need to reset your phone, that might solve the problem. a full master reset should work.
Jun 07, 2008 | Samsung SGH-D600 Cellular Phone
Configure NAND on Start up
I finally wound up deleating the base map useing the Maintenance codes, which has now left me with another problem and that How do you rload the basemaps from Mapsend Lite?
Stewart
Mar 16, 2008 | Magellan eXplorist 500 GPS Receiver
GPS freezes up
i know how to fix this. I got mine fixed with this 3rd party application "uploadGPSserial". Uploaded a map basemap which i found on the internet then mapsend works fine.
Nov 30, 2007 | Magellan SporTrak Color GPS Receiver
Problem with gps
i know how to fix this. i fixed mine. Use "uploadGPSserial" to upload a basemap which i found on the internet. then u can connect with mapsend.
Oct 17, 2007 | Magellan SporTrak Map GPS Receiver
Magellan MapSend WorldWide Basemap (980640) Maps Software Logo
185 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
