Comfort-aire wpc30 air conditioner: water control valve does not shut off completely when compressor shuts down.
    Guru:
  • 1,524 Answers
Dirt most likely.
Posted on Jun 02, 2010
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
When you switch to defrost or the air conditioner, the vehicle shuts down completely
Does it shut off, like the electrical system shuts off and the engine slowly stops (the same as when you turn off the ignition)? Or does it stop abruptly and with a noise, like a squeal or thunk? If it is the former, then it is a short (or bad ground) in your air conditioning system. If it is the latter, then, yes, it could be the compressor bearings are seized.
Nov 29, 2011 | 2004 GMC Envoy
I have a Comfort aire RAD 101-5 window AC. It works fine until it gets really hot outside and then sounds like it's bogging down and the compressor shuts off.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 14, 2011 | Heating & Cooling
I have a window air conditioner, Maytag, the compressor keeps running and will not shut off. I have tried turning it off and on, but it still runs. I tried to turn it off by the button on the AC, but...
The compressor is controlled by a contactor (relay) the relay is stuck (contacts burned or if a solid state relay the "smoke has leaked out" :) it may require a control board change if it is a modern unit
Apr 13, 2011 | Maytag Portable Air Conditioner M6P09S2A
Turn on unit starts blowing cold air for about 5 minutes the compressor kicks off. will not come back on. you can turn it off and back on and compressor will start back up again for about 5...
soulds like when it starts the high pressure switch kicks it out when you turn the power off you equalize the pressures check you coils and filter they need to be cleaned most likely this is the problem
Sep 11, 2010 | Comfort-Aire RAD-243 Air Conditioner
My air conditioner just shut down like it has no power but the outlet has power. Is there a reset button or something? It's a Comfort Aire Model RAD-151-B
Many window units now have a GFCI plug. If the power cord, where it plugs into the wall, is huge, it should have a reset button on the face or side of the plug.
If not, then a power fuse on the control panel has blown, or the control panel has died.
Aug 14, 2010 | Comfort-Aire RADS-151 Air Conditioner
I have a Sharp Comfort Touch AC displaying E-1. ??
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Jul 26, 2010 | Sharp Heating & Cooling
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Compressor shuts down 59516.531G
Is the compressor too hot to touch when it shuts down? This would indicate a low charge
Aug 02, 2008 | Dometic 57915531 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
