Question about Samsung SyncMaster 204BW LCD Monitor
My monitor plugs in blue power button blinks why ?
  • 5 Answers
There is probably a failure of part of the power supply pcb. If the light blinks and the screen is totally dark, this is the likely cause. The usual culprit is decective capacitors on the pcb. See other posts on this subject here. This failure may be intermittant; in other words, it may not always occur.
Posted on Jun 02, 2010
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
My 19 inch monitor no longer comes on....the blue light on the on off button blinks..and that is all.....help.
Please check if all the cables are properly plugged in. If yes, then remove the vga cable with the blue plug from the back of the monitor, make sure that you do not remove the power cable. if you see monitor self test or any colors on the screen it means that the monitor is fine. but, if there is no display still you need to change your monitor.
then the problem is in the tower, please check the power supply if it is working or not. If yes, the problem is either with the mother board or the memory.
Thanks and Regards
Anand Sachan
Oct 25, 2010 | Princeton Digital Computers & Internet
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
The monitor doesn't power on properly
you can have bad capacitors on your power supply.
Jan 10, 2010 | Computers & Internet
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
It won't turn on.
The inverter has failed.
Jun 22, 2009 | Famous Brand F1703 Monitor
Computer power button for the monitor blinks blue
there are two reasons for this to happen there are blown capacitors inside the monitor and or there transistors on the board that have failed. both can be repaired.
Feb 25, 2009 | Proview PL926WBi 19" LCD Monitor
Screen is blank.
Could have blown some capacitors inside the monitor.
I just fixed one today that had no power, the blue ring around the power button didn't even light up when plugged in.
I open it and found 3 bulgingcapacitors on the power/inverter board.
They were all 25V 470uF rated capacitors.
Went to radioshack and found 2 35V 470uf, got them at $1.29 each, then I found 1 50V 470uF out of a dc car power adapter for an ipod, it was as close as I could find.
Replaced the 3 broken/bulging ones with the new/salvaged ones, put it back together, plugged it in and the blue light came on when I pushed the power button.
Plugged it in to my laptop with vga cable, and it works great.
Oct 24, 2008 | Samsung SyncMaster 932B LCD Monitor
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Dec 08, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Open Questions:
Samsung SyncMaster 204BW LCD Monitor Logo
574 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
