Question about Motorola Mobility RAZR V3
It shuts down completely or shows a flat battery
When by battery started showning that it was flat after 10 minutes use I got a new battery. Now the problem persists. The phone will shut down unexpetedly or go to a grey screen. I would prefer to keep this phone.
  • Anonymous Apr 10, 2008
    Battery discharges while being charged phone brand new 4/8/08 battery replaced by Verizon now the phone is going to be replaced.
    Brigadier General:
  • 7,752 Answers
You can take the phone and have them reflash the firmware on your phone....if that does not help the problem then you need to replace your main-board.
Guest, - just take the phone baxck and have it replaced
Posted on Apr 13, 2008
After driving long enough to get to operating temp if I shut it off and then try to start it ithin 10 minutes it acts as if the battery is dead. won't turn the starter but battery shows full charge an
To recharge the current taken out of the battery during start up requires at least 10 -15 miles driving. Driving less than that, progressively drains the battery available power until it has not enough power for another start. Such a battery "resting" for more than 10 minute might regain enough power for a start but is inherently flat. Put it on a battery charger for at least 12 hours or go on a 2 hour or more drive. It should be OK for quite a number of starts even when doing short distance driving. If it is showing the same symptoms directly after to 12 hour charge/drive get the battery tested at a garage or battery dealer who will be able to tell if the battery needs replacement. If the battery test OK there might be bigger problems like a blown top gasket or problems with the starter motor.
Aug 20, 2014 | 1991 Toyota Supra
Forcd Factory Reset
best learn the principles of your tablet first
first when a battery is less than 10% it takes up to 5 hours to recharge not 5 minutes
next many tablets do not recharge when in operation so you have to shut down to allow the recharge to work
because the battery was dead flat , of course it will reset as that is the same as removing or installing a new battery
Nov 11, 2017 | Polaroid 7-in. Internet Tablet - Other
2002 dodge grand caravan. Started. Idled for 30 minutes at -20 C. Had not defrosted and powered down like it lost last of power when I opened the door to get in. New battery last week. New serp belt and...
check the battery with a volt meter-if it shows 12.5v its good-if not charge it overnight and check volts in the a m-strange that it had not defrosted-check the anti-freeze level-if no antifreeze it could have shut its self down-let me know what you find -Denny
Nov 19, 2013 | Cars & Trucks
1999 astro/4.3L/starts cold /runs 10-15 min. then dies will not start hot new coil/clean filter/pump 2 yrs old installed new/battery shows 14 amps when running/ won t crank when hot either/...
car shuts off when it gets to normal operating range. it takes 10-15 minutes to reach normal range. causes: low coolant, failing coolant tempurature sensor, air in water pump, check the coolant temp. sensor. if it is bad it will send wrong info to engine when hot, and shut it down. ITS WORTH A TRY!! good-day!
Sep 15, 2011 | 1999 Chevrolet Astro
Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Sep 26, 2008 | 1993 Chrysler Concorde
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Player shutting down after 10 seconds
Shutting down completely like power is gone or just DVD stopping with power on? If completely shutting down the look in power supply and find bad capacitor and replace. If DVD stops with power then look at laser, clean or maybe damaged.
Sep 14, 2007 | Polaroid PDV-1002A Portable DVD Player
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
