Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Horizontal lines When the TV first turns on, a bunch of gray horizontal lines appear at variable positions.  After a short period of time, the screen usually clears up.  This also occurs when the channel is changed or when the video transition between different scenes rapidly.  What are the possible causes?  And how difficult would it be to resolve? Thanks, Toy
    Scholar:
  • 170 Answers
Check all caps in power suppy and vertical. but i would point to the power supply first. the last tv i seen with this problem, i ran it for 20 minutes, and turned it off and felt the tops of all caps, found one or more that was hot. there was the bad caps, without the headache of checking all of them on the cap checker. this might not work for you. not all bad caps get hot.
Posted on Apr 10, 2008
How to fix horizontal lines appearing on my Samsung TV
its a screen fault
if lucky and you can get one
one of the electronic boards inside the TV needs replacing
Mar 07, 2017 | Samsung Televison & Video
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
I have a sharp tv 21" if i turn it on or change channel,pink display will appear with red horizontal lines about half inch intervals dn a few seconds it will turn normal but the red horizontal lines remain...
my sharp tv was like that to but our tv color was blue with also gray horizontal lines i did cheack all d caps resis... etc dont know what to do LoL.
Feb 07, 2010 | Sharp Televison & Video
TV screen goes blank for a short period of time,a horizontal line appears mid screen, then picture comes on again. Problem starts about 30 min. after turning on and gets progressively worse. This is on a...
The problem here is heat related and can be as simple as poor solder connections at the vertical IC or a defective IC. If you can supply the make and model, more detailed information can be posted. If you can solder, there you may be able to fix this your self. Please update this with the make and model as well as whether or not you wish to attempt the repair and additional details and instructions will follow.
Thanks,
Dan
Aug 20, 2009 | Televison & Video
A horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
Dec 23, 2008 | Computers & Internet
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Panasonic CT-32D11 TV
Your vertical output IC has stopped working. This is usually caused by the solder joints cracking loose and the IC will either short out inside or just stop working. Sometimes a small capacitor next to the IC, called the pump-up cap, will go bad and cause the IC to fail. In any case, the vertical output IC should be resoldered or replaced and all circuits checked by someone experienced in repairing TV's.
Aug 05, 2007 | Panasonic CT-32D11 32" TV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
