Vertical Do you know which is the vertical chip for a Panasonic TV model PC-33SF80A Chasis YAMEDP214 SERIAL CB23160071 YEAR 1992
  • JAZCAT Apr 10, 2008
    I couldn't see IC451 on the board, but I did see IC2303 and the chip was a sony CXA1279S. I'm not too sure what that chip does.
    Problem Solver:
  • 8 Answers
The vertical chip of Panasonic TV is coded as IC451 on the PCB board.
Posted on Apr 09, 2008
  • Anonymous Apr 11, 2008
    oh ic. ic2303 coulnt be the vertical IC . the vertical IC looks like a standing type. with a heat sink in it and has about 9 pins only its use is to give pump up signal to the deflection yoke and also gives signal to the horizontal circuit and make the TV powering up .
SOURCE:
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Panasonic CT-36G34 TV vertical deflection circuit
there is a single ic you need to find, usually location ic301 or 401---it will have between 7 and 13 pins in a single straight row---a generic number is printed on the front---usually begins with a LA but can be different
Locate the chip and gain access to the bottom of the board, the pins on the chip break loose from heat==SOLDER ALL THE PINS BACK AND YOU SHOULD BE GOOD TO GO---its a very common problem in these sets.
12_19_2012_7_41_26_pm.jpgsomething like this with more pins possible--will be attached to metal of some sort to keep it cool.
Dec 19, 2012 | Panasonic CT-36G34 36" TV
What's your problem?40-42 inch Theater View Toshiba TV, Date on TV is June 1999. Picture slowly started shrinking from up and down. Model no. TZ50V51 Serial no. 77988872 chasis no. 9951
you're experiencing a vertical deflection issue and will most likely need to replace the deflection board. You can get a deflection board for your model from www.tvrepairworld.com
Oct 18, 2011 | Toshiba 57H81 57" Rear Projection...
We have a very old small television which we would like to know the year it was manufactured please. The serial number is: FE 8560125. It is a National brand and will probably be in the region of 30...
Hi.
Here is a breakdown of info for your tv.
National TV was part of the Panasonic Matushita corp. up until1988 when it was renamed Panasonic.
You tv was made in June, 1985, FE related to which model and plant it was made at, and the serial number tells the date and number of the device.
85 is the year.
6 for the month.
And, 0125 means that it was the 125th tv manufactured at that plant that month for that model.
If it is still working, then you are veryblucky, as most of these were never made as an export item out of Japan, except for a few that were made for New Zealand and Australia.
I hope this helps you out.
Good luck to you, and have a good day.
May 07, 2011 | Televison & Video
Vertical line
replace the vertical ic chip
Feb 14, 2010 | Panasonic TH-42PX60U Television
I have a Panasonic TV pc-29x92 wich has a
Yes there are 2 capacitors that are usually bad one they are both very close to the vertical output. one is a 100uF at 35Vor 25V and the other is usually a 220uF at 25 or 16V- Replace with 100uF at 50V and 220uF at 35V- and observe the polarity(+,- symbols on caps) before replacing.
Oct 07, 2009 | Televison & Video
Toshiba 36A50 Horizontal Line
Ok, The vertical Ic is IC301 Ta8427K And Capacitors around IC chroma 2.2 uf 50 volts. You will see small red capacitor ( with C302....4 or 5 ) reference. Replaced others capacitors on vertical section 220 uf 35 V or 100uf 35V. I hope this can help you. Or if do you have any picture chasis, send to me and I will show you where are the problem., Thank you
Dec 12, 2007 | Toshiba 36A50 36" TV
1998 TV worth repairing?
sound like a vertical collaspe vertical chip...might be more..the fact you still have sound is good.. not all is lost. but technician will have to determine if further damage has occured
Dec 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Green Convergence
Hello, I have the same problem and was told that I needed a new convergance chip. They told me who deals in the problems where I live, (TV Repairman) It will cost me 300 for a six year chip and 350 for a life time chip! I was told by the repairman that these chip only last up to 6 years if they are not lifetime. I see alot of this same problem going on right now. These tv were manufactured in 2001, but no one was ever told that these chip would need to be replaced in so few years after spending all that money on the TV. Pasonic would not tell me the price of the chip nor how to get one,were very unwilling to help with the problem other than telling me who do go to locally, so you would have to go thru a tv service where you are.
Jul 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Ekse
