Question about Samsung HL-S6168WX DLP TV
Samsung HL-S6168W DLP is making a popping (cackling) sound and beeping noise. Audio on television goes up and down, sometimes the voice audio is loud and background is low and then vice versa. Sometimes the tone is low and then it goes high. Picture is nice and clear, and no blinking of lights on front panel. Unplugged the power for half hour and still have problem.
    Problem Solver:
  • 7 Answers
SAMSUNG DLP SOLUTION. this will fix your problem. I fix a similar model to Samsung HLS4666w model. Chasis number bp41-00278a as printed on pc board. I added capacitors to each of the three dc to dc converters on the main board. You can download the data sheet for ic212 (MP1583dn). Main board is where all the external connections are made from outside). Remove the metal cover which covers one third of the main PC board. To test this fix, only one of the dc to dc converter needs a capacitor. Location IC 212 is the dc to dc converter of major interest and will fix all problems. Add a capacitor on top of capacitor presently located at location c217 as printed on the pc board. Do not remove any old capacitors at these locations. Be careful with polarity of capacitors. Do not place this capacitor on the ic pins of MP1583dn. The voltage at location c217 should be STB 3.3 volt. You could also place the capacitor at location BD212 (+3.3) and ground, instead of on top of capacitor, if you need more clearance. BD214 and ground for converter ic 213 or on top of capacitor C236. At capacitor C212 for ic211 or at BD210 to ground. The value should be 33 uf or more, anything less will have limited fix. I would not pass 60 uf. I place a 33 uf capacitor with a working voltage of 35. This fix not only work for popping noises from speaker, but it also improve the colors. Solder with caution, leave no speck of solder behind. good luck. search the web for free service manual. Just solder the wires on that hatch door switch.
Posted on Apr 30, 2013
  • francisco abreu May 30, 2013
    The solution above has fail. It only solved temporarily possibly making problem worst. The sound starts cracking and popping after approximately 35 minutes, than the sound goes out completely. I suspect something is overheating worst now, possibly a LDO Voltage Regulator. I will investigate and post again.
  • francisco abreu Jun 14, 2013
    [B]I found a solution to the sound problem, which was causing popping and static sound from the speakers.[/B] This was also shutting down the audio after watching TV for some time. I place a heat sink on IC 987 part number stv8258DSX. This IC controls the sound and is overheating. The cause is unknown to me. Its easy to place a heat sink. Direction: cut the heat sink to size allowing room for a nylon nut. make as tall as possible. drill hole in center, but drilling only to its center, not through it.. Use nylon screw and nut (plastic). Insert the screw through the hole in the grill cover metal and than thread the nut to it. place the heat sink on top of the IC and place the grill cover back on aligning screw in the hole. (Don't forget to use thermo compound between the heat sink and IC). pull up on the screw while turning clockwise to tighten. I left the TV playing all night to the next morning and sound remain normal. I even turn on SRS sound mode.
    Problem Solver:
  • 9 Answers
I would check the speakers see if the anything is getting hot, take back cover off make sure you dont look at lamp. Tape down switch to lamp door and see whats making noise.
Posted on Jun 02, 2010
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Getting a loud popping noise thur speakers till it warms up , samsung dlp hl-s4676s
Check the highvoltage board for a loose solder joint. Sound like a loose solder joint.
Jan 27, 2011 | Samsung HLS4676S Television
I have a loud humming noise comeing from my tv
Check power supply filter capacitor that goes to Audio IC.
Apr 02, 2010 | Samsung DLP HL-P5663W 56" TV
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
Sansung DLP HL-P4674W Is making this loud humming noise and the oicture is now in black and white
sounds like a the color wheel blown. Call a local tv repair shop. Some Samsung models carry two different color wheels for same model depending on chassis version which can be seen only when the back is removed.
Dec 08, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R5067W
defective color wheel needs service
Sep 09, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S6168WX DLP TV Logo
449 people viewed this question
Henry  Thomas
Henry Thomas
