Question about Niles MSU250 Repeater
Power failure on Niles MSU250
Power failure on the Niles MSU250.. had a little rain storm and the eye on the receiver is no longer working to control the remote. Could the storm have blown out the device or just the power cord?
I have a 2007 Mazda 6. We recently had severe rain storms and the next day my power locks stopped working and the turn signals come on but no longer flash. The locks work manually but not with the unlock...
first i would open my side panels and fuse boxes to make sure it is all dry , take it from there it sounds like moisture problem in one of the relays or controllers
Oct 25, 2017 | Mazda MAZDA6 Cars & Trucks
Niles ZR-6
I had the same issue as Brian, the Niles ZR8630 stays in initializing mode. At first, the unit would not turn on, so opened it and replaced the fuse, power was restored. But now the unit continually stays in INIT mode.
any body has an answer/solution?
Jul 30, 2012 | Niles ZR-6
I have an Onkyo TXNR609 home theater receiver hooked up to a 6 speaker surround sound setup in the living room. I also have 2 speaker pairs outside - one on the downstairs patio and one upstairs. I was...
If you haven't done already, then verify that zone 2 works without the selector. If the speakers definitely work and the zone output definitely works then the speaker selector must be the culprit! It's pretty difficult to mess up the wiring with speakers, as even if polarity is reversed, you will still hear something.
Sep 23, 2011 | Niles SSVC2 Two Pair Speaker Selector...
Niles audio zr-4630 powers on then shows error code e1
Power cycling?!?!? Are you serious?!?!? Do you work in tech support?? Power cycling , what a genius.
Feb 02, 2011 | Niles ZR-4630 2 Channels Receiver
What do codes e2 and f1 mean?
Here is what the manufacture says about it, my comments are below.
F1 E2 - UL A/D error(s)
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Phil's comments----->
F1 Codes are related to the control itself, if there was a storm, power outage, surge etc it could have damaged the control. Try resetting the board by unplugging the range or turning off the breaker for a couple minutes. Restart and see if that helps. If not you will need to replace the control.
The part number for this unit is 4453614 and runs just over $300.00
Apr 25, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
Receiver remote no longer works
It sounds as though your remote is working fine. Since the storm coincided with your problem I would say that your receiver suffered a power surge that damaged the infrared receiver inside the unit. One other thing to try is to unplug the unit from the wall for about one minute, then plug it back in and try it. If that doesn't do the trick you will have to send it to a repair facility.
Good Luck,
BB
May 16, 2009 | JVC Audio Players & Recorders
Unusable new oven after ice storm
HI. the storm has caused an electrical surge that traveled through the home wiring system and, the Oven control received the hit in this case. it is damaged at this point, and it should be replaced asap, if possible. this code represents a major control breakdown. the board is ruined.
replace it asap.
Dec 17, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Niles ZR-4630
Thanks for the update. Did you try power cycling the unit?
May 22, 2008 | Niles ZR-4630 2 Channels Receiver
Niles MSU250 Repeater Logo
59 people viewed this question
Top Niles Computers & Internet Experts
David Payne
David Payne
Are you a Niles Computer and Internet Expert? Answer questions, earn points and help others
