Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears garage door opener doenst work, light on on wall pad lights on on remote sensors. nothing happens when button is pushed.
    President:
  • 3,197 Answers
I would remove the logic board and check for loose or missing traces on the logic board.
Posted on Jun 03, 2010
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sears 1/2HP opener: The outside keyless pad works, both remotes work and the sensors activate when you cross the beam but the primary inside switch (the one with the lock feature and light button) does...
It could be the wall control or the wiring to it. Easy way to test the wall control is to remove it from the wall and use a screwdriver to temporarily short the 2 terminals together. If it still doesn't work you will need to short terminals #1 and #2 together on the back of the motor unit. You don't have to worry about getting shocked. There isn't enough voltage there.
Apr 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have Garage Door Opener from Sears. Wall push button & the the remote from my car open the door OK , but it does not close the door from my car (which is programmed) Wall push button close the door...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote does not open door
I think you'll need to reset the wireless connection. Try pushing the button on the machine, then something on the pad. (or vise versa)
May 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
The wall button has a green light that is blinking and the car remote will not operate the garage door but the wall button works
this just happened to us today as well. the wall pad has three buttons: one large back-lit button pad to open it and a lock button and a light button. the open button was blinking quickly and would open the door, but the car remotes did not work. I found that by pushing both the "lock" and "light" button at the same time for about 3 or 4 seconds, the back-lit "open" pad stopped blinking and went to steady green. I went back to the cars and checked the remotes there. both opened the door.
hope this helps someone out there
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
135 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
